586,069 active members*
3,363 visitors online*
Page 4 of 4 234
Results 61 to 67 of 67
  1. #61
    May 2008
    110
    la_coterie
    Nice design, would you post the patent number for the bearing?
    budP
  2. #62
    Jul 2006
    1062
    pmsl...I'll wager the makers of this design may object. Jet Rail.....Pat Pending was the nutty Professor in Whacky Races...Wasn't he?
    Keith
  3. #63
    Nov 2008
    Cool
    I hope the setup works as good as it looks. Im using the setup in my new design..
  4. #64
    Oct 2007
    6
    Quote Originally Posted by M1K3 View Post
    Hello
    If the cnc is made of wood you will have big problems with banking/deformation of the gantry from side to side. You should make the gantry support much higher and even better if you put a support at the bottom of the gantry.
    In an aluminium cnc you will have same problem but it´s much smaller.
  5. #65
    Nov 2008
    Hey thanks for the input! The machine will be made of steel and will have a bottom support as you have drawn. My last cnc I built was wood and suffered terribly from the problem you speak of. Im trying to lighten up the machine significantly as Im not sure how much weight the skate-o-rail setup or the 1" bars will handle..
  6. #66
    Oct 2007
    6
    You can make the gantry support higher and have the same weight if you put some holes in it. Just an idea.
    If you want to calculate the deformation in the middle of the bars you can use these formules.
    deformation in your unit = (F*L^3) / (48 * E * I)
    E(steel) = 210000 N/mm^2 or 135483600 N/in^2
    I(solid bar) = (pi*D^4) / 64
    I(pipe) = pi*(D^4-d^4) / 64 D=outer diameter, d= inner diameter
    If L = 30", D = 1", F= 100N about 10 kilos or 22 lbs
    I = pi*1^4 / 64 = pi/64
    deformation(in) = (100*30^3) / (48* 135483600 * (pi/64)) = 0.00846" or 0.21 mm
  7. #67
    Re: Skate-o-rail (patent!)
    Hola amigos, soy de Perú quizás alguien tiene algunos planos para hacer rodamientos lineales caseros por favor.
Page 4 of 4 234
  1. Questions on rail covers, dual servo hunting,and rail preload
    By Plugger in forum Uncategorised MetalWorking Machines
    Last Post: 05-14-2011, 05:00 AM
  2. Patent?
    By rweatherly in forum Vectric
    Last Post: 02-01-2010, 04:16 PM
  3. Light duty skate-O-rail
    By Rhodan in forum DIY CNC Router Table Machines
    Last Post: 10-25-2007, 05:25 AM
  4. A question on bearings......to skate or not to skate
    By HiString in forum DIY CNC Router Table Machines
    Last Post: 11-12-2003, 08:46 AM
