586,121 active members*
3,643 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > DeskProto 2D Operation - Not Sure Tool Path is Correct
Results 1 to 6 of 6
    Oct 2009
    75
    I have setup a 2D operation for the final finishing operation.
    However I am not sure that the toolpath is correct. It appears that it just stays on the surface. What can I check?
    Greg
    Aug 2012
    181
    Re: DeskProto 2D Operation - Not Sure Tool Path is Correct
    In the view options you can see the tool path.
    Then you can check your segment settings If there is actually material to remove.
    Gesendet von meinem Galaxy Nexus mit Tapatalk
    Feb 2010
    62
    Have you correctly set the "Machining level" in the 2D Operation parameters (General tab) ?
    Oct 2009
    75
    Quote Originally Posted by Lennings View Post
    Lex, that was the missing piece I needed. I am now expecting a good result.
    Thanks!
    Greg
    Oct 2009
    75
    Looking closely at the graphic, it appears that the tool path goes through the bridge.
    Do the 2D operations "see" the bridge?
    Greg
    Feb 2010
    62
    Hi Greg,
    Sorry for the delayed response: normally I get an email when a new post is present here, however for some reason that did not work in this case.
    The answer is a simple no: indeed the 2D operation does not see the 3D geometry. That brings the advantage that you can easily use a 2D toolpath to actually machine the results of the 3D toolpaths.
    You can make a 2D operation see the 3D geometry by checking the option "Project 2D contour on 3D Part geometry" in the 2D Operation parameters, further see the Help button on that page.
    Lex.
  1. Multiple profile operation tool path issue
    By Craigpat in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 01-25-2014, 09:38 PM
  2. Help choosing the correct operation
    By cobrakai in forum SprutCAM
    Last Post: 01-12-2014, 08:12 AM
  3. Mill jumping but LinuxCNC shows correct path
    By thegrandwazoo in forum LinuxCNC (formerly EMC2)
    Last Post: 01-11-2013, 06:25 PM
  4. Replies: 3
    Last Post: 10-07-2011, 05:45 PM
  5. Torchmate not following correct path
    By MoparJon in forum Torchmate
    Last Post: 09-09-2008, 07:35 AM
