Hello,
I am in the process of rebuilding my gearbox in my 2001 VF2 and the rebuild kit came with new hi/low gear limit switches. The wiring harness has open ends so its meant to be spliced into the factory harness. Unfortunately the colors are slightly different. The original harness has 2 blacks, 1 brown, and 1 blue. The new harness has 1 black, 1 black/white, 1 blue, and 1 brown. The blue and brown are obvious but I cant seem to figure out which black wire does what on the factory Haas harness. The new limit switches have a diagram on the face of the switch so if I could find out which black wire from Haas does what I could get this issue solved. Any info would be greatly appreciated.
Jim
