586,501 active members*
3,220 visitors online*
IndustryArena Forum > CAD Software > Uncategorised CAD Discussion > How to draw fuselage formers in geomagic
    Apr 2013
    I am trying to figure out how to design a model airplane fuselage in geomagic design elements. I have a good idea on how to use a lofted surface to get the fuselage shape, but I cannot figure out how to draw formers to fit inside the lofted surface
    Aug 2010
    23
    Re: How to draw fuselage formers in geomagic
    I'm relatively new to GM, and am using GM Design V16. But...
    I tried a simple loft between two planes...a circle to a square. Then inserted a plane, parallel and halfway between the two ends. This is the point for my "former". I then did a Section View on the former plane, activated Sketch on that plane, and did a Project-to-Sketch of the section view face. This gives a sketch of the cross section of the loft at that plane, which is what I assume a former is. Hope this is what you want.
    Ken
  1. Alibre to Geomagic?
    By jevs in forum Uncategorised CAD Discussion
    Last Post: 12-16-2013, 07:40 PM
  2. There is no one in Geomagic design support
    By L98FIERO in forum Uncategorised CAD Discussion
    Last Post: 08-16-2013, 02:46 PM
  3. Replies: 1
    Last Post: 07-15-2013, 02:26 AM
  4. Wanted - Foam aircraft fuselage blanks
    By RaWe in forum Hobby Discussion
    Last Post: 02-07-2008, 02:58 PM
  5. creating aircraft fuselage
    By rcnicke in forum Solidworks
    Last Post: 03-16-2006, 04:45 PM
