586,108 active members*
3,066 visitors online*
    Mar 2005
    44
    Fanuc 3t power supply
    I have a Fanuc 3tc that I believe the power supply to be bad in. Is there any reason that I could not put two atx(pc) power supplies together to replace this power supply. I should be able to get 24 volts, +/- 12 volts and 5 volts from this configuration. Any ideas or concerns would be helpful at this point.
    24221
    That a pretty heavy duty power supply so I don't think PC power supplies will cut it.
    Al.
    Albert E.
    Mar 2005
    44
    only power supply for the control
    I am looking at only replacing the control power supply. The computer part of the machine.
