586,065 active members*
4,327 visitors online*
Results 1 to 8 of 8
    Feb 2005
    829
    Build Planning CRP4848
    So, I have a joes cnc 2006 and hope to purchase a CRP4848 in the next 2-3 months.
    I am just looking for some feedback on the purchase.
    I am primarly going to be working wood and plastics like most people, with the occasional aluminum cutting.
    Should I go nema 34 or nema 23, is the extra grand worth it. Reason I ask, the speed benefit for the nema34 doesnt seem that great. When I get the CRP4848 at first it will just have a hitachi router on it, but eventually I want to go to a 2.2KW Spindle.
    And I just noticed one of the suggested threads on this post. The nema 34 Uses 1000w of power. o.0
    Probably going to go nema 23, the power out in the garage is questionable at times.
    So if I go nema 23 should i get the low inductance 320oz/in motors or hold out for the 381oz/in motors on the g540?
    Oct 2008
    1632
    Re: Build Planning CRP4848
    I have the CRP4848 standard with Pro Drive kits, running an ESS + G540 @ 48 volts and the NEMA 23 steppers rated for 320.
    I have absolutely no problems with this machine as far as speed or power. I can run rapids as high as 800 ipm but I have them set very conservative at 400 ipm right now.
    At 800 ipm, every great once in awhile it would miss a step or two, but I really didn't spend a lot of time tuning. I just dropped the rapids and carried on. I know I could go back and optimize it but I have had too much fun cutting and it's been fairly issue free and the 400 ipm rapids are honestly fast enough for what I do right now.
    I run the G540 + Keling 381's on my small SX3 mill and they have done real well also, but a totally different application and gearing.
    Richard
    Mar 2011
    584
    I've had the nema 23 (381oz) & G540 for a couple of years on my 48x48 and have no regrets. I'd buy them again in a heart beat. I've had the rapids up to 500 but normally run at 400 for rapids and cutting between 80-200ipm.
    I've also done a bunch of aluminum cutting with it and it works pretty good.
    Feb 2005
    829
    Now I am also exploring getting some new power run to the garage. would a 20amp circuit be enough for nema 34 + hitachi m12vc? When i get the spindle it would be on 220 we already have in the garage.
    Oct 2008
    1632
    I'm running a 20 amp 220 volt circuit to my CRP4848's main junction box. That powers the following: Control Box, Computer, 3hp VFD and Spindle, and was also powering the 2hp HF Dust Collector but since I moved it outside it is now on a different circuit. So yes, if you have your VFD on it's own 220vac circuit, then 20 amps of 110vac would be more than enough. The dust collector would have to be on it's own circuit and would most likely have to be 15-20 amps depending on which one you get.
    Richard
    Feb 2005
    829
    Dust collection just going to run a ridgid 9amp shopvac thru a Oneida Air Dust Deputy, works great on my current cnc machine.
    Feb 2005
    829
    What about going with hybrid steppers? Would seem like a great way to get that little bit more accuracy in a machine, without costing a fortune.
    But they're not any more accurate.
    Steppers are very accurate. You tell them where you want them to go, and they go there.
    Unless they're losing steps.
    And unless there's a problem somewhere, you shouldn't be losing steps.
  1. Starting New CRP4848 build
    By rwskinner in forum Avid CNC
    Last Post: 08-09-2014, 01:51 PM
  2. CRP4848 build log - Coeur d'Alene, Idaho
    By cncrr in forum Avid CNC
    Last Post: 03-02-2014, 01:54 AM
  3. New CRP4848 Build from Central Texas
    By TurnTex in forum Avid CNC
    Last Post: 10-01-2013, 10:40 PM
  4. Planning for a CRP4848
    By vbgraves in forum Open Source CNC Machine Designs
    Last Post: 03-19-2013, 01:31 AM
  5. CRP4848 Build has begun
    By Silver-Fox in forum Open Source CNC Machine Designs
    Last Post: 12-27-2012, 03:18 PM
