586,075 active members*
3,958 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Hardware > Laser CO2 Tubes, Diodes, RF and Power Supplies > Replace 30 watt C series epilog laser with 60/55 watt C series tube
    Jul 2012
    Smile Replace 30 watt C series epilog laser with 60/55 watt C series tube
    Have a Epilog 36EXT 30 watt system, laser tube running low is going to need replacement. In looking at replacement tubes the placement of a 60 watt tube appears to fit. Has anyone upgraded a 30 watt Coherent Model C laser with a 60/55 watt Coherent Model C laser in an Epilog 36ext laser. If anyone has suggestions or really any constructive advice your help would be greatly appreciated. In essence its dropping in a 60 watt into a 30 watt system.
    Dec 2012
    Re: Replace 30 watt C series epilog laser with 60/55 watt C series tube
    You have a expensive problem
    you have to buy a new tube and a new power supply should be well north of
    10k
    Quote Originally Posted by jrich View Post
  1. Changing from 60watt to 80 watt laser tube
    By clayne in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-14-2016, 03:50 PM
  2. free cnc plans for a 50 watt epilog laser cutter
    By beverageexpert in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-26-2010, 03:41 AM
  3. Epilog Summit EX Laser Engraver 25 watt
    By aussie_mick in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-02-2010, 03:40 AM
