587,072 active members*
3,179 visitors online*
    Jan 2012
    23
    Smile turning on 4th axis
    I want to start using my 4th axis to turn spindles and newel posts.....does anyone have any thoughts on which software would be best for this....be very gratefull for any input...regards Ash
    Apr 2004
    5739
    Re: turning on 4th axis
    You can't really "turn" parts on a 4th axis like you can on a lathe. For one thing, it goes a lot slower. So you need to have a fluted tool in the spindle that revolves at a pretty fast rate, unlike a lathe where you can use a fixed tool. If you're sticking to radially symmetrical parts, the software isn't too complicated; you can use any program that will take multiple passes at a given depth of cut, starting from a profile.
    But really, parts like that are best done on a lathe; it goes a lot faster, and the tooling is a lot cheaper.
    Andrew Werby
    Website
  1. B-Axis Turning in NT
    By Jonnis in forum Mori Seiki lathes
    Last Post: 10-16-2019, 02:52 AM
  2. 4-axis turning
    By slideleft in forum Mastercam
    Last Post: 07-30-2010, 07:09 PM
  3. add u-axis for turning
    By yepingapple in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-24-2009, 04:43 PM
  4. C Axis Turning
    By pinguS in forum Fanuc
    Last Post: 09-22-2006, 10:20 PM
  5. 4 Axis Turning
    By Carbide1 in forum GibbsCAM
    Last Post: 09-14-2005, 08:44 PM
