586,389 active members*
3,120 visitors online*
    Aug 2005
    158
    GECKO G540 CAUSING MACH 3 TO CRASH
    I had the machine configured and everything seemed like it was working just fine. The G540 was bought from Automation Technology Inc (March 2012) just before the rev 8 came out and Mariss said it was a Rev5 that I have. I had it sitting in my cabinet since then and only got it hooked up last week. I am running WinXP sp2 like I do on all my other machines with no issue. The problem occurs when I 1st start up Mach (Latest version) when the power has been off for a while. If I unplug the DB25 while start up, Mach never crashes, I can then plug in the db25 and take it out of Estop and it works just fine. If I have the db25 plugged in while powering up the computer and then start up mach I can't get it out of Estop and almost every time the computer crashes. I thought the PC might be the Issue. The port is configured properly in the Bios. I tried 2 other different brand PCs and same crap. I even tried older versions of Mach and no luck either. All the PCs are 2ghz+ and I have run the driver test it says it's excellent. Usually if I restart the PC again with everything plugged in and powered up it works the 2nd time around. I'm at my wits end with this. All my previous experiences when running stepper motors with Mach 3 have been with cheap China drivers and breakout boards. I bought the G540 as everyone kept telling me it's WAAAAY better than the china stuff I've been buying. I really beg to differ. I tried it with and without the charge pump and no luck. I've never had an issue with the cheap stuff ever it just worked from the start and keeps working. I'm hoping the g540 is not faulty and someone can suggest something that I might be just doing wrong. Any suggestions will be appreciated!
    Dan
    www.decalpro.ca
    Aug 2005
    158
    Re: GECKO G540 CAUSING MACH 3 TO CRASH
    Spent 1/2 the day today trying to figure this out and I think I've solved the problem. The G540 doesn't like my Cydom Solid State Relay. I tried to use another new ssr and it seems to piss it off consistently. Went to a 24v contactor and all seems happy now.
    www.decalpro.ca
  1. Need a little help setting up mach 3 and a Gecko G540
    By Ben520 in forum Community Club House
    Last Post: 06-30-2013, 04:58 PM
  2. Connecting 2 Gecko G540 to Mach 3 for ATC
    By tgab101 in forum Gecko Drives
    Last Post: 01-22-2013, 05:52 PM
  3. Can't get Gecko and Mach 3 talking after crash
    By Rdcress in forum Shopmaster/Shoptask
    Last Post: 07-16-2011, 12:38 AM
  4. mach 3 won't run motors w/ Gecko g540
    By Super Coffee in forum DIY CNC Router Table Machines
    Last Post: 01-20-2010, 07:37 PM
