586,042 active members*
3,839 visitors online*
Thread: BOBCAD FONT
    Jun 2010
    42
    BOBCAD FONT
    I have both Bodcad V24 and V2 for solidworks. My question is this. There is a Bobcad font within V24 and it is a single line font. Is there a way to load this font into window to be used in solidworks?
    Re: BOBCAD FONT
    I'm not sure about that but you can load these -
    CamBam Stick Fonts
    into Windows
    Apr 2009
    3376
    Re: BOBCAD FONT
    Quote Originally Posted by magicniner View Post
    CamBam Stick Fonts
    into Windows
    Thanx for that.They appear to work fine in V 25
    BoB's own Fonts AFNT #1-10 are also stick Fonts.
    Jun 2015
    6
    Re: BOBCAD FONT
    idk about loading fonts into solidworks but If you are looking for a stick font in solidworks.
    go to SKETCH TEXT. uncheck USE DOCUMENT FONT, click FONT.
    Select OLF SIMPLE SANS (the letters look a little weird in the dropdown box, but it is the one you want), type the text you want, attach text to curve or line, click ok
    From there you just explode the text, then you can select the geometry in the Engraving toolpath screen.
    I hope this helps.....
    Dec 2008
    4548
    Re: BOBCAD FONT
    Quote Originally Posted by islandracing View Post
    You would explode the font in BobCad and then just export the geometry to V2 for solidworks....
  1. how do i add a font???
    By nrsmith911 in forum GibbsCAM
    Last Post: 04-14-2022, 10:29 AM
  2. Font Help
    By Dawgonhawg in forum MetalWork Discussion
    Last Post: 09-13-2013, 06:53 PM
  3. What font?
    By Darth Yoda in forum BobCad-Cam
    Last Post: 11-25-2012, 11:11 PM
  4. bobcad/cam machining font
    By chaz6966 in forum BobCad-Cam
    Last Post: 06-08-2010, 02:19 AM
