Re: How to keep trucks tight to rail?
Originally Posted by
rlrhett
That sounds like a good suggestion. It's amazing how a design morphs as you build. This is obviously a fusion between the Momus design and the fla design. Somehow the gantry ended up father above the bed than I would ever need.
I'll raise the bed up 6". I was thinking of adding a vacuum hold down like mr donek has on his website. This will be the perfect excuse for more fiddling!
I'll report back on results.
Thanks again!
Solid suggestions to raise the bed up. I definitely think you'll see a benefit there. If it's still a problem, you may also want to try the z-axis interface plate instead of the front mount plate. The Y and Z carriages in that configuration are mounted to a plate instead of the extrusion, which makes them less susceptible to slipping out of position. Also, you may try switching to extended carriages as they offer 4 hold down points over the 2 on the regular carriages.
Nate
Fine Line Automation
Home - Fine Line Automation
www.finelineautomation.com
