Well I made my last jig for my motorcycle clevises. Got everything cut and went to press in one of my locating pins and it exploded. With no real pressure on it. Didn't have a spare. So had to drill a temporary dowel pin in. OK no problem. Got it all set and cut a sample set (2 pieces). To my disbelief, they came out perfect. Awesome! Went to cut the remaining 5 sets and the mill throws a external stop requested when I was only in like 45 seconds. OK weird. Check my speeds and feeds and I am only cutting .1 deep on a long 3/8" endmill at 24ipm. And this isn't even a full width cut. OK says I can do it but maybe because the piece is not solid (the pieces are suspended and held in by bolts) I have to go slower. Slow the feed down and get in about 3 minutes and it happens again. OK. Change my speed to 18ipm and depth to .8. Again it happens. Can't figure out why. Keep playing with the speed and it keeps happening. After at least an hour of experimenting I pull the bit out to look at it and it seems fine, but I (finally) notice that it is sticking WAY out of the collet. I actually pulled the bit out. Take it apart and the inside is soaked with coolant. Clean it all up and try it again and it throws it again! WTF! Luckily I got in my 1/2 long endmill today and I switch over to that and everything comes out roses. Sucks that the hour cut took me 4 hours though!
I did shut off the estop just to make sure it wasn't that tripping because of vibration. I would have thought I would have broken the endmill before the machine would throw the estop. Weird.
-Keith:devious:
