586,354 active members*
3,258 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Strange Issue with 2010-4 Screen Set in second machine profile
    Dec 2010
    34
    Question Strange Issue with 2010-4 Screen Set in second machine profile
    I purchased and used the 2010 screen set some time ago and it has worked great up until today. I just completed a modification to my CNC router (Home Built) to add 3D printing capabilities. I changed my 2010 screen set to the 2010-4 set in my router profile to add the 4th axis (I figured I could eventually use this as an Indexer) and all works well. I added a second profile named 3D Printer. I copied the router .xml file, renamed it and replaced the 3D .xml file. I verified all settings and so far so good. The only problem I have run across is the Reference buttons across the top of the screen will not work when running the 2010-4 in the 3D profile (This is the 5 red and blue buttons used to home the axis's). I can use my gamepad buttons (used as my pendent) and switching the screen set back to Mach's 1024 screen set works fine. Also the buttons do work just fine in the router profile. Any one have any ideas on this?
    Thanks in advance for any help.
    Re: Strange Issue with 2010-4 Screen Set in second machine profile
    Copy all the macros from Mach3\macros\2010 into Mach3\macros\your_new_3D_xml_name_folder\
    Dec 2010
    34
    Got It, Thanks Gerry.
  1. Mach3 2010 Screen set
    By ger21 in forum Screen Layouts, Post Processors & Misc
    Last Post: 02-12-2024, 06:45 AM
  2. screen set in profile?
    By Johanan in forum Screen Layouts, Post Processors & Misc
    Last Post: 12-30-2013, 05:19 PM
  3. 3D CAD 2010 to dxf to G-code issue
    By tmann_008 in forum Uncategorised CAD Discussion
    Last Post: 09-25-2012, 05:14 PM
  4. using new screen with old profile?
    By groomden in forum Mach Software (ArtSoft software)
    Last Post: 10-23-2009, 06:44 PM
  5. Need Help Interact Series 1 MK2 strange startup screen
    By BrianP in forum Bridgeport / Hardinge Mills
    Last Post: 07-15-2008, 11:09 PM
