586,061 active members*
4,602 visitors online*
IndustryArena Forum > CAM Software > Vectric > PhotoVCarve and VCarve Pro > need some tip/trick to execute a design
    Mar 2014
    Question need some tip/trick to execute a design
    Hello,
    I need a help i am new to this software( Vectric Aspire) n m trying this design but not able to achieve
    satisfactory result for the side steams.
    From, what ever i know about this software , i think this will be done through extrude and weave_single rail
    or may be 2 rail extrude m not sure. though i tried single rail but did not got satisfactory result.
    It will be a great help if some one can tell me how to execute this design also/or if possible if someone can make
    only one steam for me n provide me the file so that i can do R&D on it and the the complete work.
    I am attaching the img for your reference
    awaiting for some positive replies
    Attachment 230314
    Thanks and Regards
    P.S : i am using 4.0 vectric aspire
    Re: need some tip/trick to execute a design
    I'd use 2 rail sweeps. Here's a quick, very rough sample. I put the vectors for the stem and leaf on separate layers to make it a little more clear?
    You really should spend a lot of time watching all the tutorial videos, and practicing. It takes a lot of skill to create high quality reliefs. Aspire is just the tool, you need to learn how to use it.
    Mar 2014
    Thanks gerry for your valuable time and support.
    Actually this much i have already cracked it
    this is the output i achieved before posting here Attachment 230318
    But i actually got stuck at bring this feel of moalding
    plz refer this img Attachment 230320
  1. How do I load and execute a program off of floppy
    By bill guinn in forum Milltronics
    Last Post: 11-18-2020, 05:35 AM
  2. Replies: 8
    Last Post: 11-07-2013, 01:53 PM
  3. How to execute a cnc program without logging to the execute mode of the graphical use
    By sabreen in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-04-2008, 12:29 PM
  4. How can I execute an m-code in the middle of a toolpath?
    By GeorgeRudd in forum Uncategorised CAM Discussion
    Last Post: 12-29-2005, 09:29 PM
  5. How do you make Bridgeport execute program?
    By Bill Gillen in forum Bridgeport / Hardinge Mills
    Last Post: 06-14-2005, 02:26 PM
