Originally Posted by
cncuser1
To that is this shielding connected? Mains ground, PC ground ( via the breakout board) or not connected to anything?
The mains ground and PC ground is usually the same thing as the PC power supply has a ground to PC chassis and the switching supply common is generally connected to the ground plane of the MB which in most cases has at least one grounding screw through to case.
There has been many previous posts here on grounding which will expand on this if you do a search.
It pays to set up a common ground plate or bus for all grounds.
Al.
Albert E.
