586,110 active members*
3,254 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Cadet V4020; Alarm 2154 SAT Full Error
    Question Cadet V4020; Alarm 2154 SAT Full Error
    I have a Cadet V4020 with an OSP5020 Controller that is giving a 2154 Alarm.
    The screen reads:
    2154 SAT Full Error 20083
    I went into “Edit Mode”.
    Pressed “Delete” soft key.
    Typed “*.*”
    Pressed “Write”
    Which Deleted ALL of the saved files.
    Then pressed “Condense”
    then “Write”.
    The problem still exsists.
    Machine “FREE” Command Reads as Follows:
    Total Sectors Available 40/$0028
    Total Bytes 10080
    Tape Store Length 25m
    I do not understand what this information is telling me unfortunately.
    I also checked all of the wiring and inspected MIIB:
    Okuma Opus 5000II Main Board II B
    E4809-045-091-E
    I did not find anything obvious wrong.
    My thoughts are that there are more than one memory chip on this board and some of them have become inoperable.
    Can you please tell me if I am on the right track, if so, is there any way I could determine which componant(s) are bad and replace them myself as opposed to replacing the entire board.
    Dave
    Feb 2009
    6028
    Re: Cadet V4020; Alarm 2154 SAT Full Error
    I'm afraid if it is a bad bubble memory chip, your out of luck. Been NLA for years now. Replacement board is a RAM board with battery back up.
  1. Cadet V4020 with 5020m Control Error Help
    By CNCoperator123 in forum Okuma
    Last Post: 12-11-2015, 08:31 AM
  2. Okuma Cadet 999 Alarm A
    By MTIjake in forum Okuma
    Last Post: 12-11-2013, 07:32 PM
  3. 1993 v4020 2136 bubble memory rear error
    By brandonzp in forum Okuma
    Last Post: 07-11-2012, 07:47 PM
  4. Okuma MC-V4020 pitch error comps
    By cncvern in forum Okuma
    Last Post: 10-30-2010, 05:02 AM
  5. OKUMA Cadet-Mate V4020 question
    By kyrbe in forum Okuma
    Last Post: 04-17-2008, 06:42 AM
