586,626 active members*
2,391 visitors online*
Results 1 to 8 of 8
    Jul 2012
    19
    Chiron FZ12 W Fanuc 21MB
    Hi again guys,
    Ok, I'm not sure if anyone will be able to help but I would like to know how to use the part counter, and run time counter on our Chiron FZ12 W Fanuc 21MB.
    The counter does not appear on the POS Screen , or indeed anywhere I would expect it. We do have a CUSTOM GRAPH button that brings up a screen with a soft key option of COUNTER. This brings up a screen with RUNTIME and PARTS, however I am unable to reset the figures and the figures do not change upon programme end. I have set Parameter 6700 6710 etc. I have assigned M40 as the count, but nothing changes on the screen. I hope someone can shed some light on this . Cheers all.
    I have attached 2 pics of the screen .Attachment 230946Attachment 230948
    Sep 2011
    78
    Re: Chiron FZ12 W Fanuc 21MB
    try Offset/Setting button till you get settings page, scroll down to thirth page, counters are visuble on most controls.
    They can be changed in MDI-mode.
    Nov 2010
    89
    I agree on Duivenhok
    Jul 2012
    19
    Hi guys,
    nope that doesnt work, as I said the only screen with a counter on it is the "Custom Graph" as pictured.
    Jan 2011
    350
    Maybe param 3108#4 WCI
    On the workpiece coordinate system screen, a counter input is:
    0: Disabled.
    1: Enabled
    Sep 2011
    78
    try in mdi mode #3901=10
    if counter changes to 10 then you find out if it works do #3901=0 to reset counter to 0
    put in program before reset/rewind #3901=#3901+1 to make the counter count plus 1
    #3902=100 should make a message appear when 100 pieces have been produced.
    Jul 2012
    19
    Hi guys
    duivenhok, #3901=10 brings up illegal variable number error
    botha.y that bit is set to 1
    I think I will give up . Thanks for your efforts everyone.
    Sep 2011
    78
    Try in mdi mode #1=1
    If it accepts this than macro b is installed and you van program a custom counter.
    Verstuurd vanaf mijn GT-I9300 met Tapatalk
  1. Siemens 810 on Chiron FZ12
    By Rotormac in forum SIEMENS -> GENERAL
    Last Post: 02-25-2023, 02:15 PM
  2. Chiron FZ12 with siemens 810M . Softkeys not working.
    By terrycoughlan in forum SIEMENS -> Sinumerik 810M/810T
    Last Post: 04-09-2015, 07:06 PM
  3. FANUC 21MB Hardware connection manual
    By dinesh in forum Fanuc
    Last Post: 04-20-2011, 04:17 PM
  4. CNC Mill155 Fanuc 21mb Problem..
    By n8wing in forum German
    Last Post: 12-27-2009, 02:49 AM
  5. Fanuc 21MB & Renishaw MP40
    By Andrew_K in forum Fanuc
    Last Post: 02-22-2006, 04:07 PM
