586,075 active members*
4,255 visitors online*
    Apr 2014
    help configuration SCM RECORD 220 ROUTECH
    Hello. this is my first post, i hope someone can help me.
    i have this SCM RECORD 220 ROUTECH, we recently changed the CPU cause it was malfunctioning , some troubles with the HDD, we installed all the software on the new CPU no biggies, it connects and everything, problem here is that the SCM marks an error and blocks all the system, it says that the axys are not calibrated.
    i still have the backup from the previous HDD , it has all the files, i was wondering if there is a file that contains information i could use to recalibrate the SCM, or if somehow i can transfer the configuration from the NUM to the CPU .
    in the worst case it does not exists how can i recalibrate the axys so it can work again.
    thank you very much !
    Oct 2018
    Re: help configuration SCM RECORD 220 ROUTECH
    hi,
    I need a copy of a backup for SCM Record 220
    can you help me??
    Sep 2008
    100
    hi
    Can you share me the backup?
    Regards
    Hi sr
    Do you have the electrical diagrams and manuals
  1. Routech Record 130 w/ NUM Controller Help
    By dnormand25 in forum Commercial CNC Wood Routers
    Last Post: 02-14-2017, 08:24 PM
  2. problem with cnc scm routech record 220 with num 1040 controller
    By mahamaha in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-27-2016, 05:10 PM
  3. help please with scm routech cnc machine
    By salmankh in forum Commercial CNC Wood Routers
    Last Post: 08-01-2013, 03:15 AM
  4. Xilog Plus - Aspire - Routech Record 132
    By Rampage Dave in forum WoodWorking Topics
    Last Post: 10-23-2010, 10:14 PM
