586,100 active members*
3,046 visitors online*
    Oct 2011
    65
    Sub spindle facing question
    When facing a flat part on sub. I always get a small tot at center. Anyone have a good solution. Material is 303 ss and I'm using a circle bar with 0 nose rad. Have this problem on our K16 as well as our L20.
    304
    Re: Sub spindle facing question
    If you are using a bore bar, the normal tool is set below center. That will leave a "nub" at the center. There are "Turning Bars" made for this type of cutting. You can also get adjustable holders that will help with this if your machine is not perfectly in line. See GenSwiss.com
    Feb 2008
    267
    Quote Originally Posted by colby2000 View Post
    Another option, if you have the tools available, is to use a small center drill and put "tiny" spot on the face.
    I'm talking like ...
    G1 Z.0020 F.001
    This is generally indistinguishable on the part and combats any of the positions being slightly off with respect to center height.
    Good luck.
    Control the process, not the product!
    Machining is more science than art, master the science and the artistry will be evident.
    Sep 2011
    261
    Ya, your tools is below centerline. You could rotate the tool in the pocket slightly. Since most boring bars are off center, if you rotate it slightly you can adjust the center height a little bit. You could measure the nib and then put an indicator on the tip of the bar, then rotate the bar until you raise it the radius of the nib +.001 for good measure. even of your rake angle is slightly off, it probably wont matter too much in 303.
    If that doesnt work, cheating it with the spot drill is a good idea.
    CNC Product Manager / Training Consultant
  1. Newbie facing direction question
    By Little Skippy in forum Mastercam
    Last Post: 08-08-2012, 08:43 AM
  2. Facing question, see file
    By mattfurches in forum Mastercam
    Last Post: 02-16-2012, 02:36 PM
  3. Feed and Speed for Facing off Spindle Nose?
    By WOTDesigns in forum Tormach Personal CNC Mill
    Last Post: 01-25-2012, 02:49 PM
  4. Noob facing question
    By MBX5 in forum MetalWork Discussion
    Last Post: 03-14-2011, 06:28 AM
  5. Esprit 2008 Facing Question
    By thebowman in forum Esprit
    Last Post: 12-08-2009, 07:08 PM
