I never got the Yaskawa running, it had shorted windings and went back to the seller. One thing to know at least with the Fanuc motor, this is not a bolt it on and go. It will require some higher level programming in the VFD. The motor I have says rights on the name plate "110-230 Volt" or something close to those numbers (not looking it up right now). After some testing and research into magnetic fields and inductors, I figured out that the motor I bought is the equivalent of an 1500 RPM 110 VAC 3 phase motor at 50 Hz. But at 8000 RPM it is 230 VAC 266.66 Hz. Take a look at this chart to see the difference. There is a lot more to all this that could take up a couple posts but this is the short version of it. Depending on the VFD used this might not be a problem, for the Hitachi I am using it is not.
Attachment 260564
The Fanuc motor has a powered fan just like the factory motor on the Novakon. Most wide RPM range AC motors that I have come across have separate powered fans. At the low speeds a shaft driven fan will not move enough air, and high speeds they could come apart or at least add a significant load to the motor. With that said when I ran the Fanuc on the bench I did not have the fan powered.
On the topic of powered fans, I recently have found that the metal bodied muffin fans have the capability to transmit a lot more noise into the the machine they are connected to than the molded plastic fans. I am actually looking for some new fans for my electrical cabinet, because the 220 VAC all metal fans I bought are very annoying when the machine is on but not cutting.
Well I bought my spindle and an air/hydraulic release cylinder from there and I got the items. From what I gather its like a ebay for vendors in China. They advertise their goods, you can contact them and find out more info. Unlike ebay its not an auction, so no bidding. When I bought the spindle Aliexpess processed my credit card and held it in a escrow until I went in and left feedback and told them to release the funds to the vendor. If I had not gone in and done that Aliexpress will pay the vendor after 30 days from the time the vendor claims to have shipped it.
