586,111 active members*
3,463 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > help dimensions of hitorque x2 dimensions?
Results 1 to 6 of 6
    Jan 2011
    38
    For those who have a HiTorque mini mill or upgraded the column to one. Can you provide the dimensions of the column and the locations of the mounting holes please? I am thinking of the using the column on a hunk of metal to make my mill.
    Jan 2010
    2141
    Re: help dimensions of hitorque x2 dimensions?
    I have the solid column upgrade from Little Machine Shop but have not yet unpacked it from the shipping box.
    If nobody else chimes in with the dimensions I should be able to check them for you, but it may take a day or so for me to be able to get to it.
    Jan 2011
    38
    Thanks. I tried searching the forum but no luck.
    Jan 2010
    2141
    Please identify which dimensions you are looking for:
    Attachment 232684
    Jan 2011
    38
    The location of the mounting holes, hole size and the general overall dimensions please
    Jan 2010
    2141
    These are rough dimensions only:
    Column height: 20-3/4"
    Column width: 4"
    Column depth (not including dovetail): 2-1/8"
    Column depth (including dovetail): 2-1/2"
    Base dimensions (not including dovetail): 6-1/8" x 2-3/4"
    Base hole centers located at the corners of a rectangle 5-3/8" x 2"
    Base hole diameter: 0.323" (P drill bit)
  1. I need help with cnc dimensions
    By crodriguez1517 in forum Controller & Computer Solutions
    Last Post: 01-07-2012, 05:40 PM
  2. EMC - bad dimensions
    By Smooth90 in forum LinuxCNC (formerly EMC2)
    Last Post: 02-22-2011, 08:04 AM
  3. Red Dimensions Why?
    By Rally in forum Mastercam
    Last Post: 02-17-2010, 02:30 AM
  4. TL2 Dimensions
    By AMCTony in forum Haas Mills
    Last Post: 11-22-2006, 06:57 PM
