Hi
I'm looking for a stepper motor that have high torque as well as the option to have quite high rpm.
During my search I have found what seems to be two different "types" of motors. Or it might be that their specs are presented differently, and that is why I'm writing this post.
Stepper 1: http://www.ebay.com/itm/271436920030?ssPageName=STRK:MEWAX:IT&_trksid=p398 4.m1423.l2649
1000RPM Rotary Speed 1.7A 4.5kg.cm Torque 4 Wire Stepper Stepping Motors
Stepper 2: http://www.ebay.com/itm/CNC-Nema17-Hybrid-Stepper-Motor-2-Phase-48mm-4-Lead-1-8Degree-2-5A-/321134741362?pt=LH_DefaultDomain_0&hash=item4ac51f 4772
CNC Nema17 Hybrid Stepper Motor 2-Phase 48mm 4-Lead 1.8Degree 2.5A
Stepper 3: http://www.ebay.com/itm/NEMA-23-Stepper-Motor-12-6Kgcm-1-8Degre-4Leads-56mm-57BYGH56-401A/251301932447?_trksid=p2045573.c100033.m2042&_trkpa rms=aid%3D111000%26algo%3DREC.RVI%26ao%3D1%26asc%3 D22042%26meid%3D6178603913913735288%26pid%3D100033 %26prg%3D9536%26rk%3D2%26rkt%3D4%26sd%3D3212963116 85
NEMA 23 Stepper Motor 12.6Kgcm 1.8Degre 4Leads 56mm 57BYGH56-401A
The first stepper has a voltage rating from 12-40V
The second has a voltage rating of 3.1V (from table in description section)
The third stepper does not have a voltage rating at all, but have the absolute highest torque.
Is there any way to - from the given information on stepper 2 and 3 - to understand what rpm these two steppers will be able to run up to?
