I have an OD feature that requires me to Unwrap faces/edges to sketch, but when i do it it does not work right. Not sure what i'm doing incorrectly. Can anyone help? I have a picture of the feature attached. Need to mill this feature out.
Hi
I cannot understand you please , you doing this by CAM Software or ,Machine direct , which type machine & Software you use
thanks
You have your rotary axis set for Z -- change setting in machine tab.
Create a plane above the z+ for unwrapping.
Your model doesn't look like you need to use a wrap feature -- mho
