586,111 active members*
3,183 visitors online*
Results 1 to 8 of 8
    Jan 2006
    37
    Stepper stall
    Hello, im worknig in a custom machine to wind bass guitar pick ups. Im trying to have a stepper at 5 RPS(well its selectable from 1 to 5RPS). It has an acceleration till it gets to 5RPS. When it gets to 5 rps it takes about 3 or 4 seconds to stall(i thinks its the right word, i mean the motor stops). It does a a kind of a progresive sound till it stops. If i load the motor a bit(with my hand) it wont do it and it will keep turning, if i let go it will take 3 or 4 seconds and it will stop. Wierd thing is that its also doing it at 5, 4.5, 4, 3.5, 3, 2.5 and 2 RPS. Its stable at 1.5 and 1 RPS.
    I think it could be resonance problem. But im not sure.
    Anyone has ever runned accross something similar??
    The driver im using is a l297 l298 with a nema 23 motor.
    Thanks, Matias.
    That is mid-band resonance. The motor makes a descending growling sound, then stalls.
    Mariss
    Jan 2006
    37
    Is there a way to avoid it??? In the begining it didnt do it. What surprises me is that now it is doing it at a really low speed.
    any ideas or suggestions???
    Thanks, Matias.
    Jan 2006
    37
    How could a new motor work fine girst and then have this resonance problem.
    Any places where i can find mor information???
    Thanks, Matias.
    Mid-band resonance is a motor behavior. It is most severe between 5 and 15 revolutions per second.
    Being a resonance, something has to trip it off. It's always there, hiding until something triggers it. That "something" is a load torque disturbance (an abrupt load change).
    Here's how you can test a motor / drive for resonance:
    Run the motor at 600RPM lying on its side on a hard benchtop with no load attached. Pivot the motor up from the benchtop 1/2" using one corner of its mounting flange as a fulcrum. Rotate it back down with a sharp bang onto the bench surface and press down firmly on the motor. The motor should immediately breakout into resonance and stall in a second or two.
    Drives that have midband compensation circuitry will not resonate.
    Mariss
    Jan 2006
    37
    Thanks Mariss, u have been very helpfull.
    I tried with another motor and it works just fine even at 10RPS.
    Now the question is, why a new motor that worked fine at 5rps now it cannot even rotate at 2 RPS. Cuold it be that it got demagnetized or something like that, cause right next to the motor i had the transformer.
    I dissasembled the motor and the rotor doesnt have a strong atracction to metals, in other motors i dissasembled it was stronger.
    Hope someone can help withs this doubt.
    Thanks, Matias
    That is a more serious mistake. Never disassemble a step motor and remove the rotor from the stator. Doing so demagnetizes a motor.:-(
    I ran some tests on that a few years ago and posted the results on the CCED group. The test was to run dyno tests on a motor to get a baseline, then disassemble the motor, remove the rotor and immediately put it back in and reassemble the motor.
    The motor had less than 50% of its original torque when it was re-tested on the dyno. It was demagnitized in the few seconds it was removed from the stator which acts as a magnetic "keeper".
    Mariss
    Jun 2003
    3312
    ezcnc, did you dissasemble the motor before you had the problems?
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
