Hi All,
I'm rebuilding my Novakon NM145 mill, swapping out the original motor and VFD for an AC induction motor and appropriate VFD. I'm moving the electronics cabinet from the back of the mill to the wall behind it which means replacing the wiring between the cabinet and the mill due to the longer run. The wiring from the C11G BOB to the VFD for analog input is shielded. I'm planning on the wiring from the VFD to the motor to be shielded and the E-stop wiring to be shielded as these were shielded in the original setup. None of the other wiring was shielded. Is there any benefit to be had from using shielded wiring in other locations such as from the BOB to the drivers, drivers to steppers, or between the BOB and proximity sensors? Thanks for any advice you have to offer.
Curt
