586,121 active members*
3,758 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > Chamfer hole located on an angled
    Oct 2011
    65
    Wandering what is the best way to program a chamfer on .0591 hole located on 22.5 deg. Slot. Running this on a Citizen K-16E. Material is 2024 Alum.
    Sep 2011
    261
    Re: Chamfer hole located on an angled
    I believe you could use G173 angular interpolation, but that would still require a holder normalized to 22.5 degrees.
    I looked up the tooling configuration of a K16E and I cant tell if the bottom live tool can be set at an angle like a L type 8. If you cant normalize the tool to the angle, I dont know how you're going to get an even chamfer.
    If you can normalize a spot drill to the chamfer, you could use G173 (at least its G173 for a L20E type 9). The code would be something close to G173 X0 Z.1 D22.5 (I just made up the Z number. the Z would be the intersection point of the hole's centerline and the angle. I just said Z.1 because it looks about 1/3 of the way down the part)
    The G173 would make a virtual plane at 22.5 degrees that you could then program a normal G2/G3 X/Y chamfer.
    How are you making the angled slot to begin with, and can you angle a tool holder at 22.5*? I can provide a better answer when I know that.
    Also, since its not spec'd on the print, maybe just hand deburr if the quantities arent huge?
    CNC Product Manager / Training Consultant
  1. How to correctly chamfer a hole?
    By Darc in forum G-Code Programing
    Last Post: 06-03-2021, 09:10 AM
  2. Cross Hole Chamfer (G16? G12.1?)
    By Ovrclck350 in forum CNC Swiss Screw Machines
    Last Post: 02-14-2014, 04:32 PM
  3. tapped hole chamfer with iscar chamfer tools
    By dcutler35 in forum Mastercam
    Last Post: 12-07-2012, 02:30 PM
  4. CHAMFER FOR TAPPED HOLE
    Last Post: 07-03-2012, 09:11 PM
  5. Mits CX20: Initial positioning for angled start hole.
    By klrskies in forum EDM Discussion General Topics
    Last Post: 05-05-2011, 01:12 PM
