586,060 active members*
4,487 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > help with 120v vfd and 220v spindle replacement
    Jan 2013
    20
    Hello,
    I have a 6040z s80 and the spindle went out. I ordered it with the 110v 1.5kw spindle . I purchased a replacement but it is 220v 1.5w.
    The vfd is the one that came with the control box. It is labeled as a nowforever model d100s1r5b input is 1ph ac110v 50/60hz output 15.0A. The new spindle is from a ugracnc and is a 1.5 kw 220V 3 Phase (Inverter Output Voltage). Is there any chance I can use my current vfd? Ive had no issues with it.
    Thank you all for any help you may offer.
    Jun 2007
    3757
    Re: help with 120v vfd and 220v spindle replacement
    Maybe, as long you don't want the motor to run at more than mouse power.
    You did not get what you ordered.??!
    Jan 2013
    20
    I assumed the vfd was 120 in and 220 out but it looks like they put in a 110 spindle. I thought it was a 220 spindle. Pays to look at the motor before pulling it out and readying a replacement.
  1. Mach3 PWM Spindle Speed Control using 220v 1ph VFD/220v 3ph spindle motor.
    By Ozzwinkle in forum Mach Software (ArtSoft software)
    Last Post: 12-23-2013, 07:01 PM
  2. 2.2KW 220v Chinese spindle on 208v 3ph?
    By MechanoMan in forum DIY CNC Router Table Machines
    Last Post: 12-06-2011, 04:49 PM
  3. 220V europe to 120V US wiring
    By willy1067 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-25-2009, 04:05 AM
  4. VFD 220V 120V & NOISE
    By JpBinc in forum CNC Machine Related Electronics
    Last Post: 11-10-2008, 05:17 AM
  5. Yet another 120v to 220v
    By Konstantin in forum CNC Machine Related Electronics
    Last Post: 02-24-2006, 08:57 PM
