586,111 active members*
3,522 visitors online*
    Apr 2012
    25
    A axis problem
    The a axis on my bridgeport is working but only moves 1 direction.if I go a- or a+ they both move as if I werr pressing a+.I have exhausted everything I know .been through all the settings I know to check.any advice would be greatly appreciated.
    Jun 2007
    3757
    Re: A axis problem
    Check the direction wire to the driver. Probably broken, or has it never worked?
    Jun 2004
    6618
    Re: A axis problem
    A loose or broken wire will cause that as Neil suggests. It has happened to me a few times, but I usually get intermittent travel direction. Meaning it will sometimes move left and sometimes right. Sometimes several button pushes moves the same direction.
    Lee
    Apr 2012
    25
    Re: A axis problem
    Okay, changed motors, same problem , switched drives to check function. evrything works except which ever driver i went to still hasd one direction. using gecko drives, a smoothestepper. pmdx 126 BOB and PMDX 134 motherboard. all i can come up with now is that it has to be in the software or related to the expanded mode on the 126. has anyone else conquered this problem. i have a feeling it is quite simple( most things are when you get down to it.) thanks again-Andy
  1. a problem with slaved A-axis moving properly relative to Y-axis
    By zool in forum Mach Software (ArtSoft software)
    Last Post: 07-06-2011, 03:45 AM
  2. my 4th axis problem
    By nasrace10 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-15-2009, 03:59 PM
  3. z axis Problem
    By grahamshere in forum DIY CNC Router Table Machines
    Last Post: 01-15-2009, 12:19 AM
  4. problem x axis
    By jlviloria in forum Hyundai Kia
    Last Post: 09-24-2008, 03:28 PM
  5. VMC Z Axis problem
    By cam1 in forum Uncategorised MetalWorking Machines
    Last Post: 04-18-2008, 10:11 PM
