Hey! I finally am back to work on this project! I was able to do some work on the neck this weekend. (I copied this post from a post I just made over on Project Guitar.com
First thing I ran into was a problem The angle of my scarf joint was 2 deg more than my cad model. To fix this I set the neck up at the correct angle and milled the face of the headstock flat.
angle fix
While I had the neck at this angle anyway, I decided to cut the shape of the head stock
headstock shape
Then I set the neck blank up in the flat postion and cut the truss rod channel and I drilled two 1/8" locator holes that will locate the fretboard. The holes are drilled at the 12th fret marker postion and will be covered by the inlay.
Locator holes and truss rod channel
Next I made a steel jig to hold the neck when I flip it over to cut the back side. The jig is a piece of 1.5 x 1.5 inch cold roll steel. On the top of the jig I milled a 1/8" tall "key" that fits into the trussrod slot of the neck. This jig give me the location for the rest of my operations.
neck jig
The next step was to taper the neck blank
Neck blank tapered
This was as far as I got on Sat night.
This morning I came to work early and started the carving process. Here is the neck about 1/2 carved.
Hopefully will have finished pics this afternoon.
