586,103 active members*
2,725 visitors online*
Results 1 to 8 of 8
    Dec 2012
    14
    TB6600 torque/testing help
    Hello. I am got my 5 axis bob and tb6600 working. Steppers are nema 23. Probably 60-70 oz/in. I also have a TB6560 that works as well. I notices that the TB6600 runs considerably cooler than the TB6560. Is this due to the 30% torque thing I have read about? The TB6600 feels much better and smoother though. Also seems to be able to run at a higher ipm. At high imp with the TB6560 the motor just shakes. Can you tell by the speed if you are getting proper torque? Or is that more important for holding. Here is a video. Sorry for the poor quality and lighting. Thanks everyone.
    https://www.youtube.com/watch?v=_Lnn...ature=youtu.be
    Oct 2010
    79
    Re: TB6600 torque/testing help
    Where did you get the TB6600 driver from?
    Are you running two motors on the same driver?
    Dec 2012
    14
    I got the driver from mibinstruments on eBay. They are listed as shipping from the US so I went with them. But actually took longer on shipping than the tb6560 I got from China.
    And yes, I am running both steppers with one driver
    I forgot to mention I am running a 24v 15amp power supply.
    Oct 2010
    79
    Did they include a schematic of the drive with it? It looks like it uses a different standby circuit then the rattam and div268n drivers.
    You should check the current draw to the drive with an amp meter.
    I also do not think you would want to hook two motors in to the same driver...
    Dec 2012
    14
    The driver came with some kinda booklet. I don't have the enable hooked up cause it's not clear how the works on the bob I have. I just have dir and step hooked up
    And what's wrong with running 2 motors? Thanks
    May 2014
    Hi ya,
    Have you worked out if your MIB board is producing full torque?
    Is this the MIB board you have? TB6600 Stepper Motor Driver Board 4.5A CNC engraving driver board
    Thanks Daniel
    Dec 2012
    14
    Quote Originally Posted by danielfarley View Post
    Hi ya,
    Thanks Daniel
    That appears to be the same board. As for torque, if you read this entire thread you know as much as I do lol. I was hopin someone who knew might chime in but it hasn't happened yet. If temperate is any indication it is probably reducing torque because the motor bl gets much hotter much quicker with the tb6560. I need to order 2 more drivers but am not sure if I should get tb6600s or tb6560s or one of each again
    364
    It's impossible to comment without schematics or measurements.
    Quote Originally Posted by MaddCow View Post
    I notices that the TB6600 runs considerably cooler than the TB6560. [/url]
    The above is from your first post and seems to indicate the chip temperature: the TB6600 will run a bit cooler in the same circumstances due to better spec's than the TB6560.
    You are mentioning the motor temperature in your last post.
    This would indicate a smaller motor current (30% kicking in to soon) if the test between both drives use the same supply, motor current settings and are done with a running motor.
    A better way to analyse the actual torque is by measuring it, there are several simple ways to do this.
    One is to mount a pulley on the motor with a wire wound on it and a weight attached to the end. Clamp the motor at the table edge and increase the weight untill the motor can't lift it anymore and stalls.
    You could even calculate the torque at that speed because you know the weight and pulley diameter.
    Beware that the weight will drop real fast when the motor stalls........
    Open source CNC electronics and accessories:
    http://users.skynet.be/ldt/CNC%20electronics/THB6064AH.html
  1. Toshiba TB6600
    By riphet in forum Stepper Motors / Drives
    Last Post: 09-28-2022, 09:18 AM
  2. TB6600 drive from EBAY
    By lucas in forum Stepper Motors / Drives
    Last Post: 05-30-2020, 02:59 AM
  3. Haoyu TB6600
    By bobgrant in forum Stepper Motors / Drives
    Last Post: 03-20-2018, 04:57 PM
  4. TB6600 experiments
    Last Post: 12-22-2013, 06:01 PM
  5. Replies: 0
    Last Post: 03-08-2011, 12:28 PM
