Hi all,
I currently work with Revit and was wondering who else out there is using it to make fabrication models. The way that I approach this is by making section views of each extrusion (or handful of extrusions coincident with a single plane) and export them into DXF format. The DXF's then get imported into Aspire. This is a manual process that I'd like to be able to streamline better. If I section it correctly, there won't be much vector cleanup required. If a part is cut on both sides, I then have to get creative and start layering in Aspire to show which vectors are cut after the piece is flipped.
If you use Revit, what is your workflow?
