Originally Posted by
bl3030
I have a part on which I have a hex shaped boss protruding from a flat plate. When I use the Surface Finish Contour tool and select the 6 faces that make up the side walls of the boss, it makes a tool path both on the outside of the boss (which does what I want) and the inside (which destroys the boss). How do I force it to just contour one side of the boss?
I've selected the "Containment - Outer" option and it does nothing. I've read other solutions about creating additional geometry to make a containment surface, but I don't quite understand it. Shouldn't the geometry I have be enough?
