586,116 active members*
3,457 visitors online*
Results 1 to 8 of 8
    Feb 2011
    4
    converting a solidworks file to g-code
    Hi guys -
    I'm reasonably new to the world of CNC - in terms of the design software. I do know a bit about the controllers and machines.
    I have a straightforward question, which may not have a straightforward answer though.
    I have a solidworks drawing which I need to convert to a g-code in order to have a part machined.
    the file was given to me, and I do not have any info about toolpath etc.
    The two files I have a .sldprt and .igs file extensions.
    Is there a specific piece of software that I should use to create the g-code or should I give the files to a machinist, and have them charge me $ for the conversion and machining??? I am led to believe different controllers require different files.
    thanks in advance
    Jan 2008
    1529
    Re: converting a solidworks file to g-code
    G code is generally generated specifically for each machine. I would not run G code you supplied without rigorous review.
    You usually supply the model and they generate the code and run it.
    Jun 2008
    372
    You will need a CAM software, There are plenty but generally they are rather expensive, The best solution would be to use a contractor that has licensed software and knows how to use it.
    Apr 2007
    80
    Hi Joey,
    Are you a Solidworks user? If so, you can download for free a CAM Plugin for Solidworks known as HSMXpress. I use it daily to create my G Code from my Solidwork files.
    Regards
    Chrisjh
    Feb 2011
    4
    Thanks Chrisjh - that's what I was looking for. Apologies for not correctly explaining to those who replied earlier.
    Apr 2007
    25
    Quote Originally Posted by JoeyB View Post
    Did you get on ok with it in the end?
    I work for the ANZ Autodesk CAM Master Reseller, selling & supporting HSMWorks, Inventor HSM & CAM for Fusion 360. Shapeoko 2 owner
    Feb 2011
    4
    Quote Originally Posted by RonnyM82 View Post
    Haha! No!
    but thanks for asking.
    Apr 2007
    25
    Haha! No!
    Would you like some help now? Or are you all set with CAM now?
  1. Replies: 8
    Last Post: 05-04-2015, 12:49 PM
  2. Converting Fanuc G code to Seimens 840D G code
    By Jasbinder in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 02-20-2011, 05:02 PM
  3. Converting a pdf file to UG part file
    By gaoxingdcf in forum UG NX
    Last Post: 05-20-2010, 01:47 AM
  4. converting a mastercam 9 file into a Solidworks file
    By Michael82 in forum Solidworks
    Last Post: 04-17-2009, 07:14 PM
  5. Converting SolidWorks to ACAD
    By ImanCarrot in forum Solidworks
    Last Post: 11-15-2007, 03:08 PM
