586,113 active members*
3,505 visitors online*
    Apr 2006
    59
    Red face Why Do Mach2' Settings Change?
    I set the axes limits in mach2's to match the physical dimensions of my machine a while back.
    This weekend, after about 40 minutes of machining, I decided the roughing steps were too fine and changed the roughing steps from 25% of cutter diameter to 100% in RhinoCAM, post-processed and tried to machine the the new g-code by starting from the same point. The cutter diameter = 6mm.
    What happened was that the previous work was cut away and the more jagged steps I expected to see did not appear.
    I gave up 40 minutes later. I checked the motor settings in mach2 and discovered they had changed - radically. They no longer matched the machine's dimensions.
    I had not effected any changes in mach2.
    Does anyone know what I did wrong and how I can keep from repeating the mistake?
    May 2005
    1810
    I have seen odd things occur with previous versions of MACH as well but I haven't had an issue with the newest version of MACH3.
    I would suggest downloading the latest and greatest version now since it appears that you will be setting everything back up - why not set it back up with a better version? MACH 3 runs the motors smoother than MACH2 anyway - you will see a noticable difference in motor control.
    Scott
    Consistency is a good thing....unless you're consistently an idiot.
    Apr 2006
    59
    Scott, I thank you.
    However, do you have a link to such a download?
    May 2005
    1810
    Yup - sure do!
    http://www.machsupport.com/artsoft/index/index.htm
    Go to the downloads page for the files. I have been running Mach3 Dev. Version 1.90.053 without issue.
    Scott
    Apr 2006
    59
    Yup. Scott is da Man!
    Thanks bud.
