586,106 active members*
3,115 visitors online*
    Jul 2012
    What Thermistor Do I need for my 80-90W Power Supply?
    Hi Everyone,
    My laser tube power supply failed yesterday and upon inspecting the power supply we noticed a black circle thermistor melted into pieces. Right now I'm having a hard time trying to figure out which one it is to buy. The only part # i see is NTC and a number 5 at the end. If someone could tell me which one it is and where to buy in California or order online I would really appreciated!
    Thank you!
    Tam
    Re: What Thermistor Do I need for my 80-90W Power Supply?
    Quote Originally Posted by tamtanium View Post
    Hi Everyone,
    Thank you!
    Tam
    Hi , Tam
    i will send the pictures to the manufacter to check if can repair for this problem .
    and also if you need DY10 Power supply .i can supply with you .
    115$/set . Support Paypal .
    For the details you can add my skype: weihonglaser.frank
    Best regards
    Frank
    co2 laser machine&parts. tubes,lens,mirrors,DSP control systems ,powers etc .
    Email/Skype:[email protected]:86-18516298692.
    Jan 2012
    43
    My response may be to late to help you, but as a electronic tech for some time now, I have seen many of these fail in all types of P.S. They are used to minimize the inrush of current the instant that the power is applied to minimize possible damage to other components. In the real world, they are mainly a pain as they are born to fail from the heat they generate, They get brittle and crack every time or the heat "desolders them" from the mounting leads. Long story short, JUST REMOVE IT AND BYPASS IT. The P.S. will work just fine.
    If you have a old time TV shop still around that serviced tube type TV'S, they could have some still in stock that I bet they would be happy to get rid of.( the new designs don't use them any longer)
    Rick
  1. Server Power Supply to power stepper motors?
    By thebuggman in forum CNC Machine Related Electronics
    Last Post: 01-26-2014, 01:30 AM
  2. Replies: 15
    Last Post: 10-29-2013, 12:58 AM
  3. Power Supply/Power Cord Sizing for Four 850 oz-in Servos, One is Slaved
    By Plugger in forum CNC Machine Related Electronics
    Last Post: 03-11-2012, 05:52 AM
  4. FANUC Alpha Series power supply input power limits
    By tcom-frazzled in forum Uncategorised MetalWorking Machines
    Last Post: 01-17-2012, 06:07 PM
  5. Power Supply from a computer power supply
    By jmytyk in forum CNC Machine Related Electronics
    Last Post: 01-11-2006, 09:56 PM
