586,207 active members*
4,026 visitors online*
    Sep 2007
    84
    First turning
    Hello,
    I have made a test code to run on my sherline. Its a 1/2" diameter with a taper chamfer rounded etc. After figuring out the basics i ran into this problem. I can't seem to get the tool to start cutting at the end of the stock. I'm not sure where to make the adjustment. I have included a screen shot.
    Thanks for your input.
    Craig
    Feb 2011
    252
    Re: First turning
    Hello,
    Attached is an example for the beginning and end.
    greeting
    solidcamx
    Mar 2011
    79
    Re: First turning
    it looks like it is starting on the left and the lead-in angle looks to be the same as the angle on the missing end. I would have to look at the file but i suspect your tool is defined wrong for what your doing.
  1. turning RFQ
    By millman52 in forum RFQ (Request for Quote)
    Last Post: 03-08-2012, 05:40 PM
  2. Turning
    By dinnese in forum CNC Swiss Screw Machines
    Last Post: 01-18-2012, 02:23 AM
  3. Pinch turning or Balanced turning
    By pradeep in forum Mori Seiki lathes
    Last Post: 09-07-2010, 07:55 PM
  4. Turning 17-4
    By shep640 in forum Mini Lathe
    Last Post: 04-07-2009, 10:50 PM
  5. Turning
    By camtd in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 08-01-2007, 06:40 PM
