586,115 active members*
3,453 visitors online*
Thread: square holes
Page 1 of 3 123
Results 1 to 20 of 43
    Aug 2005
    413
    square holes
    I have to bid a job that has a rectangular hole through 2.5" of aluminum with .062" radiuses in the corners. What is the easiest way to do this with only a VMC. I know the best would be a waterjet or wire edm but I don't have one of those and am trying to figure out how to do it in the mill.
    2.5" is a long way with a 1/8" endmill, even from both sides. I was looking at Horn's broaching tools that you can use almost like a shaper but I am not sure if they would work.
    I would like some thoughts and suggestions please
    JP
    Dec 2005
    3319
    You didn't mention the size - only the depth of the hole.
    I'd use a drill to poke a hole first, then trepan around with a larger end mill.
    Finally, use a 1/8" dia mill to shape up the final form.
    Aug 2005
    413
    It's basically an Ar-15 type magwell
    JP
    Jul 2005
    12177
    Your machine has a pretty high force capability on the Z axis. Do you have spindle orientation activated? You could mill the hole and then square up the corners by just driving a square HSS tool with the corner radiused to .0625" like a vertical shaper. I would just experiment a bit at a slow feed rate on the Z and taking only a small cut to see how the servo load goes. Even if you did drive the servo into overload and alarm out it is highly unlikely that anything will get hurt because it would not be an impact load.
    Aug 2005
    413
    Thats kinda what I was thinking about with Horn's broaching tool. I am thinking maybe I can get one of the inserts made for chamfering the sides of a keyway and round the tip to the radius I need (possibly on my tool grinder) and then orient the spindle into the corners to make the cuts. Still though I think their shanks are fairly big and all. It might be worth trying the HSS if the job looks promising.
    If only I could find a local shop with a wire edm for cheap!
    JP
    Jul 2005
    12177
    You could even bolt a carbide insert flat on the end of a piece of round bar. Even if you cannot get a .0625" nose radius plotting the X,Y coordinates to cut the corner radius would only take a few minutes.
    May 2005
    2502
    Drill the corners with a 1/8" bit. Mill out most of the core with a larger mill, such as a 1/2". Blend the corners with an 1/8" mill.
    BW
    Dec 2005
    3319
    A VMC machine tool spindle IS NOT A BROACH nor a SHAPER nor should it be used in place of one of in place of one for that matter. Nor are screw drivers chissels nor should you pound screws with hatchets.
    The bearings in a machine tool spindle will brinnell quite easily if a static load load is applied to them when the spindle is NOT turning when axial load is applied to the spindle. Since you don't know if the overload protection of the spindle is in fact callibrated for the application of a static load as opposed to a dynamic one, you can't rely upon the machine tool maker's protection circuitry to keep you out of trouble.
    If I caught an employee doing that (using the VMC as a shaper or broach), I'd fire them on the spot.
    BTW, in my younger days I did that "no no" and learned the hard way how much it costs to rectify such stupidity when I did it to a a drill press.
    Do what you want but I wouldn't do that....
    Aug 2005
    413
    Quote Originally Posted by NC Cams
    Thats kind of what I was thinking could possibly happen. I didn't really like the idea of use the spindle as a broach even in Aluminum.
    I wish I could afford a good used wire edm! Does anyone know someplace on the internet where I can learn more about wire edm's? All they ever told us in school is that they exist, we only got to work with ram style. I want to try and learn about wire for several months so that maybe if the time does come to buy one I at least know what I am getting into.
    JP
    Jul 2005
    12177
    What NC writes is technically correct but before anybody starts flapping theirs wings and saying the sky is falling it might be worthwhile checking the static axial load rating on the bearings. It is probably a good deal greater than 2000 lbs which is what the servos alarm out at (approximately). On your machine it is not necessary to factor in the head weight because it is counterbalanced.
    Aug 2005
    413
    Quote Originally Posted by Geof
    My machine does not have a counter balanced head. The newer machines have a large motor on the Z axis and they did away with the hydraulic counterbalances. I think the motor on the head put out more like 4200 lbs of thrust compared to 2500 lbs on the X and Y axis.
    JP
    Dec 2005
    3319
    The RATED axial load of bearing is based upon a number of assumptions that do NOT always end up being facts of reality in an operating machine.
    In my bearing engineering days, I've seen any number of bearings that were axially brinnelled at loads that were well below the RATED static load of the bearing.
    I"d suggest that you VERY CAREFULLY read the qualifiers in the bearing applications manuals when they talk about applying axial loads to bearings. You may be surprised at what you'll learn when you go thru a life calculation.
    BTW: the spindle engineers don't always have total say on the design or use of a machine. Thus, it is concieveable that the guys who did the counterbalancing didn't have much interfacing with the spindle guys.
    I simply wouldn't even use the VMC spindle as a ram - period. Do what you wish and live with the results, good bad or indifferent.
    Jul 2005
    12177
    Quote Originally Posted by JPMach
    JP
    Sorry, I thought we had communicated about a counterbalance one time. That does change the situation; head weight plus servo thrust could come up 6000lbs. In this case I would simply make something to clamp to the spindle nose so the load was not being taken by the bearings.
    Expanding on the topic of square cornered holes I think an accessory like a slotter or keyseater for a VMC would be useful. I have seen them for Bridgeport type machines; they clamped onto the outside of the spindle housing, took their drive from the spindle and had a vertically reciprocating tool. In a VMC they could install like a speeder or right angle head with all the support being taken by the spindle and a dowel pin engaging with a receiver on the end of the nose. The reciprocating motion would not need a long stroke and if it also had a sideways component at the end of its stroke before the retract the cutter would not rub on the way out. Something like this would make it possible to bore and keyseat holes in a single fixturing.
    Mar 2006
    19
    :eek I have broached parts like that many times.
    Jul 2005
    12177
    Quote Originally Posted by werks
    Naughty (chair) Naughty (chair) go stand in the corner.
    I have too just not with a CNC
    Mar 2005
    1136
    good gawd, does this mean you guys are all going to start buy shapers again, at least let me pick one up while they are still cheap cheap cheap! (if only i could find a good one)
    Jul 2004
    374
    I wouldn't be too concerned about your spindle with light shaping. Shaping in general uses very low cutting forces. Especially in your application, the cutting forces will be very light. To put it in perspective, think about how much material you are removing in each pass.
    However, I can see NC Cams point [about loading the spindle while not turning] and I wouldn't use a VMC for broaching on a regular basis.
    and broaching...absolutely not on my machine!
    Mar 2006
    19
    Thing is I will do it again. :wee:
    You guys must be much gentler on machines than I am. If the spindle meter is not in the red that is when I yell at my guys. We's heah to make money.:lol
    Jul 2005
    12177
    Yellow; we have max spindle load set at 120% and Autofeed kicks in to back off on the feed when it goes over this.
    Oct 2004
    15
    square drill
    Why not look for a old set of square drill bits.I have two real old sets .They can be hard to find but they are well worth it when you do find them.
Page 1 of 3 123
