My Shopmaster 2010 is tested out (to the most part) - Cleaned & Oiled up. I have the hand held RPM tool for $15.99 from amazon. (very cool). I've done Autocad 3d, and some CAM prep...I went w/ Dolphin CAM Mill PRO. I'm in IT so the computer part is easy- Now for the hard part: time to get some chips going. I'm going to practice on some scrap. W/ a .5 cutter on some 1045 steel. (which is what I work w/). I've read about using Flood, -vs- Mist, versus dry. I simply cannot see cutting dry w/ these units? So I have the Mister Unit and the 5Gal bucket and the Shopmaster water table all prepped and working.
Here is my Q: What do you typically find for using Mist or flood on the machine in general? Is there a expected typical clean up following the cut? I did read in some of JT's write ups about the stuff turning to Gook inside the machine and upon on the ball screws. Mine is the 2010 and has a cover but I'm sure will get soaked. Anyway Wanted to ask are you a Web, Mist or Dry camper? Thoughts on when and what circumstances comments very welcome and appreciated. I still wish I could have bought a new unit - But my used Gal is looking pretty nice. Time do see how she dances (And yes I realize she's only as good as her partner,,,,, Me! ) ;-)
