586,119 active members*
3,638 visitors online*
Results 1 to 18 of 18
    131
    Brother TC-228 Post (any software)
    does anyone have a post any processor for the brother TC-228?
    thanks
    Mar 2006
    1625
    I took this off of bobcad suppost and are you looking for tc-22a or tc-228
    Attached Files Attached Files
    131
    thanks for the quick reply, however i dont think that post will work. that seems to output gcode and the controller on the 228 (afaik) accepts motion programs/conversational programs which dont look anything like g-code. however i could be all wet and just havn't got the controller completely down yet.
    Mar 2006
    1625
    see if the controller will accept stander EIA for G-M code most al controller will read it or maybe stamder ISO format
    Mar 2005
    171
    I have TC-221 and it only accepts the conversational programming. I have seen Brother machines that do accept EIA/ISO (G code) programs, but I'm fairly certain
    that this is an option. Do a web search and contact Yamazen via email or phone
    with your machine serial number and they may be able to tell you whether you have
    g-code capability. If your machine is pre-1990 they may be very little help at all.
    For what software are you looking for a post?
    Can you send and receive programs via RS-232 and if so, what software are you
    using?
    Good luck
    Ben
    Jul 2006
    11
    Smile Thank you
    Thank you
    Jul 2006
    11
    I need to Know about CNC brother TC-20A and TC-203C Tapping Center
    use a program format G-code and post by SolidCAM can be use
    CAD/CAM
    Jul 2006
    14
    Many of the old Brother Converstional machines can be converted to run G-Code. The machine's control panel, and several IC chips on the NCPCB need to be replaced. Parts will typically cost around a couple thousand bucks, and take a few hours to install by a technician.
    Contact Yamazen:
    877-271-1933
    157
    We are developing a G-Code to Brother Conversational Converter at the moment. We are still using something like this in our company. The converter is able to convert any simple G-Code to a brother motion program.
    Please contact [email protected] if you are interested in this.
    Jul 2006
    11
    Thank you
    CAD/CAM
    Mar 2005
    171
    Hello,
    I've sent a couple of emails to your email link and have received no response.
    Is the g-code to brother motion control converter software available?
    I would really like to try it and buy it if it's what you say it is.
    Ben
    Jul 2006
    11
    Thank you
    My email is [email protected] please tell me Title and you name on email
    i don't know why my email not response and Thank you agant
    Ben
    CAD/CAM
    May 2009
    hi, everyone, My name is rick , Very new here, Hoping can share and learn from here.
    Thank you. my e-mail is [email protected] , My Tc228 NCPCB has spoiled ,need repairing or replacement, Does anyone know where to get a replacemnet or get it repair?
    I have the faulty NcPCB for TC228. brother.
    Thank you,
    Jul 2009
    Hi!
    I have a problem with brother TC-211.
    I get the message "POSITION ERROR (Z)" and I don't know what to do.
    Manual says just "press RESET key and check time constant"
    What exactly should I check with the time constant?
    Can anybody help me?
    Answers can also be sent to [email protected]
    thanks
    Jul 2009
    One other thing I would like to know is does anybody know how to control the additional 4th axis of the brother TC-211.
    I know that CODE 81 makes the axis move, but how do I control the angle of rotation?
    Answers to [email protected]
    thanks
    Mar 2005
    171
    It will give you this alarm if the rapids are below 250 IPM.
    To get out of this alarm, Hold the RELSE (KEY) and Jog Z down.
    Mar 2007
    Quote Originally Posted by Nksa View Post
    thanks
    That control can only send and receive m-codes which are only simple on off triggers and the port is only good for m-codes and commands to run programs already stored in the internal memory. Example you send a signal from a computer through the port that tells the mill to run internal program number 1000. M-codes are simple on off pulse, the degrees of rotation are controlled by a seperate controller for the rotary table.
    Re: Brother TC-228 Post (any software)
    can brother tc 203 cnc accept g code ?
  1. brother (conversation) mode Editor or software
    By Razahan in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-26-2022, 10:22 PM
  2. Post for a Brother HS 70A
    By ewest in forum Esprit
    Last Post: 06-03-2019, 06:48 PM
  3. Brother -S2A Post
    By toolmaker2001 in forum Mastercam
    Last Post: 03-22-2014, 07:20 AM
  4. masterCam V 9.1 to Brother post
    By toolmaker2001 in forum Post Processors for MC
    Last Post: 10-06-2010, 02:20 AM
  5. BROTHER HS-70A Post
    By asylumua in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-12-2006, 11:54 AM
