586,072 active members*
4,691 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Problem with a Milltronics VKM3 Centurion 6
Results 1 to 17 of 17
    Jun 2006
    7
    Question Problem with a Milltronics VKM3 Centurion 6
    We have a Milltronics VKM3 here that was purchased in 2002 and has only accumulated 140 hours on the machine since then.
    yesterday I fired it up to make some parts and it would not boot(this has never happened before). It hung in different spots of the boot cycle at different times. I got frustrated and went to lunch, when I came back and turned it on, it booted fine on the first try and I was able to make the parts. This morning, it was dead again.
    I talked to Bob in parts today and he thought it was acting like a motherboard problem and gave me a few things to try(reseating the ram, checking the powersupply). Neither of those appear to be the problem and the machine still will not boot. If it requires a motherboard replacement, that will be ~$1600, seems a little outrageous for a machine that is essentially new.
    Has anyone else had this problem, does anyone have any ideas?
    TIA
    Jun 2006
    24
    Maybe the battery is not holding charge there for loading off disk everytime you boot up???
    Jun 2006
    7
    I did not know that there was a battery in there. Where would I look for that?
    Mar 2006
    370
    What did you check on the PC power supply? I would pull it out and put it on the bench and run it on a scope.
    Or better yet just go get another one and stick it in. Make sure you get the right connectors on the power supply.
    There is a battery on the mother board but I am not sure how it could cause this problem. It powers the BIOS configuration memory. For it to fail at different points in the boot that to me points to the power supply or ram. I am still going with the power supply.
    Good Luck.
    Dave
    Jun 2006
    7
    I have probed the leads on the power supply while they are hooked up to the motherboard and I got the voltages that I was supposed to get. I did not probe every single lead just one each of the +5, -5, +12, -12. tomorrow I will try to probe each individual wire to make sure that it is working properly, or maybe I will just pull it out and put it on the scope. That would give me the opportunity to look at the connectors and see if I have a power supply around the lab that has the same connectors(I may finally be glad we never throw anything away).
    I'm not sure I understand how the powersupply could be making it hang at different spots at different times? If I am ever able to get it to boot all the way to the interface, it will stay on and I can use the machine until I shut it off again.
    Thank you for the advice. :cheers:
    Mar 2006
    370
    Those power supplies are notorious for going bad. They will look OK one second and not the next.
    Of course I do not know if it is the PC power supply, it could be something on the mother board but if it were me I would replace the power supply first because it is a cheep thing to try. If it does not help, let us know and we will try some other things like ram or resetting the BIOS.
    Intermittent problems are often caused by heat. To get this to be a factor leave the machine running for several hours to heat it up.
    May 2006
    4
    TIA
    I have seen some very, very wierd problems like yours that were solved when a new CMOS battery was installed. I'm thinking that the processor loses a few bits & bytes if the battery is low, especially when it sat idle for awhile. It'll be locate at the bottom of the Motherboard, and should read around 3.15 VDC, (usually have to disconnect one lead from the board to get an accuate reading). You may be able to get a 'plug-in' replacement for it, but in any case, they are usually a $10.00 item at any larger battery store (try Interstate Battery).
    Might NOT be the cause of your problems, but for the price, I'd give it a try.
    Regards
    Dave
    Mar 2006
    370
    Are you required to replace the battery with the power on?
    May 2006
    4
    Cool VMK CMOS battery
    NO, if the machine has booted up, you can read across the battery to see what voltage is on there, but if you are replaceing the soldered in version, you'll want to power down the machine. I usually pull any boards that are plugged in the vicinity of the battery out to get better access.
    Regards
    Dave
    Jun 2006
    47
    My VKM3 did the same thing. Turned out I had too many programs loaded and overloaded it. I deleted a bunch of programs and its been fine every since. Mine is an older machine than yours so that might not be your problem but its an easy and cheap thing to try.
    Mark Hockett
    Island Tech Enterprises
    Clinton, WA 98236
    360-914-6026
    More chip less lip
    Jun 2006
    7
    The problem has been solved.
    There was something wrong with the RAM, so 2 new sticks of 8mb RAM solved the problem.
    Thanks for all of your help(group)
    Dec 2007
    milltronics vkm3
    please i need help ! i need to locate the battery on my machine to replace can you guys tell me where i can find it , thank you my machine is a milltronics vkm3 it has less than 40 hours on it but it seating down for 4 years now when i start it i get a square frame around the screen which does not let me to see all the bottom keys to control my machine thank you
    Oct 2008
    427
    Your CMOS battery has died, the default video setting has changed which means the screen aimage no longer fits on your LCD display. This frequently happens on controls that use a single board computer card.
    If you have a standard mother , you should be able to replace the battery and re-set the CMOS settings without too much trouble.
    If you have the SBC, replacing the battery can be more of a problem; it is mounted in the middle of the card surrounded by lots of other components making it difficult to solder in the replacement.
    You might be able to find another card by searching the net or your dealer can get you a new card ready-to-go with software and your machine's parameters already loaded.
    Dec 2007
    need a mastercam post processor for milltronics centurion 6
    maybe you guys can help me this is my email address [email protected]
    Jul 2010
    548
    Try using a M6 or M10 post that is in Mastercam. One of these should do 99.95% of what you need to do. If not it is a good starting point for editing your own post.
    Oct 2017
    Re: Problem with a Milltronics VKM3 Centurion 6
    Quote Originally Posted by WrenK View Post
    Hi Wrenk, I think that I have the same problem you had. Where did you get the new sticks of 8mb RAM?
    Jul 2010
    548
    Hi hugfer28, I have ram available.
    PM me or call 952-288-6340
    Sportybob
  1. Milltronics Centurion IV DNC?
    By papp101 in forum Milltronics
    Last Post: 01-04-2014, 03:57 AM
  2. Milltronics centurion V program?
    By dj_pigs in forum Milltronics
    Last Post: 03-10-2011, 03:01 PM
  3. milltronics centurion 5 fault
    By courtiron in forum Milltronics
    Last Post: 02-22-2011, 02:26 AM
  4. Milltronics Centurion 5 450 error Help!
    By Footie11 in forum Milltronics
    Last Post: 11-15-2010, 10:04 PM
  5. Milltronics Centurion Six
    By CUTRITE in forum Milltronics
    Last Post: 10-13-2006, 07:48 PM
