Re: Cutting Aluminum on Techno Gantry
You're not going to burn out the servo motors by cutting with them. If you cut wet (which is a good idea for tool life and cut quality), and they get soaked, that's another issue.
It's nice to make a solid t-slot bed out of corian or MIC-6 if you're feeling generous. One where you can hold down the material, and have a drain hole for fluids to collect from.
Think about it this way: The motors would have no problem generating enough force to snap the tool, so if you're not breaking the tool, then you're well under the threshold where you'd have a problem.
Eric Feldman - Design Engineer, Programmer
Armor CNC - http://www.armorcnc.com Support hours: 7am thru 10pm EST, 7 days a week
