586,069 active members*
3,309 visitors online*
    Aug 2013
    14
    Angry In program pallet change
    I am currently trying to use an in program pallet change to install bushings after boring an i.d. We have a mori nh4000dcg. program after machining prior to pallet change is as follows: "G91 G0 G49G30Z0M19;G30X0Y0M11;G28B0;M60;M0;M60;.......... .."
    I am getting nc alarm 5010 End of record after it reads the M60 line(both ways)..... Any ideas???
    Feb 2009
    6028
    Re: In program pallet change
    Is this in MDI or auto?
    If in auto, where is your m30?
    Aug 2013
    14
    Quote Originally Posted by imjustakid View Post
    So yes it is auto. MDI is a simple M60 for pallet change, but I can't integrate it into a running program.
    No need for M30 being as I am picking up the program after the M0 stop prior to the M60 to bring it back into the machining area.
    Essentially, I just want to switch my pallet out to install bushings. After installing the bushings, I want to continue with the program I was currently running by switching the pallet back in to be finish machined.
    Jun 2014
    10
    Does M60 work in MDI mode? If it does, what I found is using M60 in a program, the button on the outside of the machine needs to be in the locked position (light on) In MDI mode the switch does not need on, just to have the doors closed.
    Hope that makes sense.
    Jeff
  1. Pallet Change
    By CNC Mendez in forum G-Code Programing
    Last Post: 01-25-2017, 02:48 PM
  2. APC wont pallet change - Need help please!
    By Iownacnc in forum Okuma
    Last Post: 12-12-2011, 04:50 PM
  3. Millac 4h pallet change program
    By fourway in forum Okuma
    Last Post: 03-04-2011, 12:46 PM
  4. Pallet Change Speed
    By 68 SS in forum Fanuc
    Last Post: 09-19-2008, 03:36 PM
  5. pallet change program, needed
    By stew in forum Fanuc
    Last Post: 01-02-2008, 08:45 PM
