586,463 active members*
3,309 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > G0704 PROBLEM please help!!
Results 1 to 9 of 9
    I'm having trouble with my machine. please watch the short video. Problem I'm having is happening at 14sec in the video. I'm running mach3 and using nema 23 570's, and a nema 34 for the Z. all axes have roton ball screws with .1265 oversized balls. The machine was built with Hoss's plans........ Motor velocity is at 120 and accel is at 4 for all axes.
    https://www.youtube.com/watch?v=270ArRpv_0w
    Nov 2009
    4415
    Re: G0704 PROBLEM please help!!
    Sounds like something is loose. I also think I am hearing the steppers stalling. Hard to tell as the noise could be a vibration from the stall. try reducing your accel and velocity and see if it makes the noise. Do you have backlash compensation enabled? It sounds as though you might. There is a noise right at the change of direction BC sounds like that upon taking up the slack. Still not the bigger noise you are hearing.
    A lazy man does it twice.
    Nov 2009
    4415
    Are you running a code or are you jogging rapidly with the keys? If it is a code for a pocket or similar you are missing steps as I can see the changes at different times in relation to the vise.
    Mar 2013
    124
    Some stalling and something loose? Check your shaft couplers and bring down the velocity/accel for now.
    not running any code in the video, just jogging the table. However when I run code on the machine sometimes it will jog itself over while cutting a pocket. I do have the backlash compensation ON, Hoss had me turn it off and try it, and the noise and problem go away.
    Nov 2009
    4415
    What do you have the accel rate % in backlash comp set to?
    the rate is set to 50%
    Oct 2004
    298
    Quote Originally Posted by DanielCarroll0283 View Post
    are you reversing before the backlash compensation has a chance to 'compensate'?
    YouTube Channel: https://www.youtube.com/c/RobertCowanDIY
    Aug 2004
    3215
    Hoss has a video of setting up backlash in mach3 you will need to play with the numbers and see what works best with your machine. it will run rough if not set up right.
    Mach 3 Backlash Compensation - YouTube
    Joe
    www.joescnc.com
    joecnc2006 at yahoo
  1. G0704 Problem
    By SB123 in forum Benchtop Machines
    Last Post: 05-10-2014, 03:10 AM
  2. G0704 AC bearing problem
    By MillingMan in forum Benchtop Machines
    Last Post: 01-30-2013, 07:33 PM
  3. Electronics problem =( g0704
    By mr.andaya in forum Benchtop Machines
    Last Post: 12-20-2012, 05:00 AM
  4. G0704 problem
    By pike3e in forum Benchtop Machines
    Last Post: 07-27-2010, 10:33 AM
  5. G0704 Gib Problem - Is this fix OK?
    By mrcodewiz in forum Benchtop Machines
    Last Post: 07-23-2010, 03:29 AM
