586,080 active members*
3,485 visitors online*
Results 1 to 17 of 17
    Jan 2006
    66
    Gecko 202 drives
    Hey guys, I think that I once saw a thread for a wiring diagram for wiring up Gecko 202's. I cannot find it any more. Is there a thread that you can direct me to for this. I am converting a manual milling machine to 4 axis cnc and I will be using Gecko 202's with 1780 oz in motors from homeshopcnc.com. I have a 1 Kw power supply already, but I am looking for the wiring information for the 202's. I will be using Mach 3 mill with this set up.
    Can anyone help out on this.
    Thanks, in advance.
    By the way this conversion article, including the ball screw conversion (already done) will be published in an upcoming article in the new Digital Machinist Magazine (from Home Shop Machinist), although not likely until the Spring of 2007 by the time I get it ready for press.
    Later,
    Pete
    Nov 2005
    938
    Pete,
    This may help. This is all I saved from the thread you refer to. I was under the impression that there would be a written summary with detailed instructions comming from that thread. Or may be I was just hoping that would be the case.
    Steven
    Attached Files Attached Files
    Jan 2006
    66
    Thanks Steven
    Peter
    Jan 2006
    30
    hey you have the motors wired as unipolar .Will the same wiring diagram work with bipolar motors.
    thanks
    Jan 2006
    30
    what is a 5 vdc supply
    Quote Originally Posted by jarr88
    thanks
    Actually, no it doesn't. It just says unipolar steppers. Geckos are bipolar drives, they can't be wired unipolar. They'll always use 4 wires.
    You can use unipolar motors with them, though.
    Nov 2005
    938
    The diagram was one that someone else put together and posted here as part of a thread with the goal of putting together a sort of "Gecko wiring for the common man" kind of thing. I didn't draw it myself. I have no clue who to attribute credit to. I assume the unipolar label is just a keyboard slip.
    Oct 2004
    742
    The Uni-Polar legend is wrong.
    Quote Originally Posted by sdantonio
    You can attribute the drawing to me.
    The Uni-Polar legend is wrong. I imported the motor and did not notice that the legend was wrong.
    The motor legend should be Bi-Polar.
    I have changed the legend, but could not delete the origional drawing or replace it without having some sort of editing priviledges.
    Here is the modified version in dxf. It also has the CNC4PC breakout board, and a diagram for adding SOLID STATE relays for external control.
    Jerry
    Nov 2005
    938
    Jerry,
    Thanks, Again, great work.
    When you mention the boreakout board for CNC4PC are you using
    C10 - Bidirectional Breakout Board
    or
    C1 - Parallel Port Interface Card
    I assume the pinouts would be similar (though may be not identical) for any other breakout boards like the one Phil has on pminmo.com for example.
    Steven
    Nov 2005
    938
    A side note for those of you who are cheep weasels like me.
    I checked with Gecko (I figure it can't hurt to ask), they said they never have and refurbed units or scratch and dent sales. Sometimes you get lucky, but you'll never know unless you ask.
    Steven
    Oct 2004
    742
    Jerry,
    or
    Steven
    The C10 Bi-directional board.
    I have personally built 5 ea. CNC control systems by the above Gecko wiring diagram, and two or three others here on CNCZone have told me they have used the schematic to build systems without ANY problems.
    Jerry
    Nov 2005
    938
    Hi Jerry,
    I was looking at the manual for the C10. Looks good, but I may still build my own from Phils plans since I have the parts already and his supports e-stop and limit switches. It doesn't look like the C10 supports those. But I may also change my mind again.
    Steven
    Oct 2004
    742
    Hi Jerry,
    Steven
    If you read the manual for the C10, then you must have missed the bold statement that says Inputs pins 10, 11, 12, 13, 15.
    Those are the pins for the e-stop and limits. He just does not furnish a wiring diagram in the documentation, but it does support them.
    Nov 2005
    938
    Thanks Jerry,
    It probably helps a lot if you know what your looking at when your looking at it This is why I try to leave electrical engineering to the guys who know what their doing.
    Steven
    Nov 2005
    938
    Hi Jerry,
    Just one more quick question.
    On the gecko drives in your diagram you specifically list every drive except the 202. I assume this was just to save space. Am I correct in assuming that the 202 should hook up and work like all the other drives.
    Steven
    If you cut it to small you can always nail another piece on the end, but if you cut it to big... then what the hell you gonna do?
    Steven
    Oct 2004
    742
    Hi Jerry,
    Steven
    Same wiring. Just an oversite on my part. All Gecko stepper drives have the same wiring.
    Jerry
    Nov 2005
    938
    I figured that was the case, but I thought I would check before sending off $400.
    Thanks again
    Steven
