586,106 active members*
3,271 visitors online*
Results 1 to 7 of 7
    Apr 2014
    345
    13x40 lathe electronics
    Ok so I have a non branded 13x40 lathe and the only identification is the model number co632 nothing else. Anyways the transformer on it went bad and smoked allot. Anyways now it's dead and I'm puzzled as to why it was there. The transformer took 110 vac from the wall and turned it into 110vac and 24vac but the only thing is it was only hooked up to the 110 output. Can anybody let me know why this is here and maybe a replacement or just verification that I don't need it.
    Attachment 234756Attachment 234754
    Feb 2007
    4553
    Post Re: 13x40 lathe electronics
    Quote Originally Posted by ianagos View Post
    Grizzly has a replacement transformer that should fit your application, see attached manual.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Apr 2014
    345
    Yea they do indeed have have it but not in stock and at $70 it's not too cheap. Do you have any other suggestions.
    Feb 2007
    4553
    Ianagos,
    eBay has a abundance of 40 to 50va 24 volt control transformers without the 110 volt isolation / stepdown tap for $15 - $30 dollars
    If in fact the 24 volts on your lathe is not being used the transformer may be removed and 110 volts connected directly, however the safety aspect of the isolation transformer would be negated.
    Jeff...
    Apr 2014
    345
    But did you even read my my post I need a 110 to 110.
    Feb 2007
    4553
    Ianagos,
    A 110 / 110 transformer is not mandatory in order for the lathe to function, just apply fused 110 to where the 110 output would normally connect.
    Jeff...
    Apr 2014
    345
    Thank you that's pretty much what I wanted to know.
  1. Looking for someone who has a Central Machinery 13x40 lathe
    By JasonFields in forum Tormach Personal CNC Mill
    Last Post: 12-17-2020, 08:18 AM
  2. 13x40 vs 14x40 lathe
    By AVRnj in forum Uncategorised MetalWorking Machines
    Last Post: 06-30-2013, 03:25 PM
  3. Wiring HF 13x40 Lathe For 110v
    By garyMc in forum CNC Machine Related Electronics
    Last Post: 04-07-2012, 02:25 AM
  4. Sieg SX3 and 13x40" lathe in Toronto
    By ticica in forum Canadian Club House
    Last Post: 05-05-2010, 04:28 AM
  5. 13x40 lathe recomendation
    By rdoty1 in forum Uncategorised MetalWorking Machines
    Last Post: 01-03-2008, 11:34 AM
