Hi everyone,
I have a Shenhui SH350 50W CO2 laser.
Can someone please send me a save-file of the vendor settings, or screenshots of the x and y axis settings (as in my attached pictures), so I can set the correct parameters?
Info on my machine:
Shenhui SH350
50 W laser
300 x 500 mm work area
Motherboard: RDC6442G (EC) (white color enclosure)
Motherboard Software versions (as displayed on built in screen when booting):
RDC-V8.00.03
HMI-V4.1.1
Stepper Motor controllers: 2M542-06 (black boxes)
PC-Software: RDCAM V6.0.37 and RDCAM V8 (makes no difference which one is being used). PC's used with Win 7 Pro, Win 7 Home, Win XP, no difference
the challenge is that the engraving (scanning) runs sideways, the higher the laser power setting is. At 12% power, it runs straight down, at 15%, there is an offset of about 1.5mm over a length of 15 cm, at 60% power, this offset is massive, and so on.
Attached a picture with 15% power setting on the engraving (the clean one), and tests with higher settings (the one that is engraved all over), so you see what my problem is.
Also, sometimes while cutting (vector based), the cut lines do not overlap on side-by-side boxes, even though they should. One line is offset by about 2mm comparred to the other.
I had the suggestion to activate the "PWM rising edge valid" option in the vendor settings on both x and y axis. This initially resulted in the slanting to go right to left instead of the typical left to right. Once this was changed again (only 1 axis is affected), then there was either no change or the laser head engraved the same line over and over.
In general, I believe the vendor settings are all messed up, or the controller box is broken.
So if someone happens to have a machine with the same motherboard (and version), etc., it could solve my problems, if yours is working properly.
thanks for your support,
best regards from Germany
