586,082 active members*
3,668 visitors online*
    Jun 2006
    3
    Angry mazak(mazatrol-m1)
    hi I have mazatrol m1 in this only one dot appear on screen no other function plz help watz remedy for that thanx
    Dec 2003
    24221
    Sounds like your monitor died.
    Can you use/remember the correct key stroke to jog or home OK?
    Al.
    Albert E.
    Jun 2006
    dot on M1 crt screen
    Seem you M1 have problem bout communication between PC card and Panel control unit
    If the communication ok the one led on PC card must blink in high rate.
    (I'm right?, If the dot on screen is one cursor blinking on top left side of the screen.)
    Jun 2006
    3
    hi you r right dot blinking on top left side of the screen
