586,117 active members*
3,595 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki Mills > Mori Seiki MV-JR with fanuc 10M and sv003 on x and y axis
    Jun 2013
    14
    We are running this machine off a phase converter that is putting out 249 volts evenly. And we are getting Ot108 24 volt to high alarm. I think I've fixed that. The spindle drive board has a switch to go from 200 to 230 and when I switched that the machine doesn't throw this alarm but before I could power the machine down the power flickered on the shop(small storm) as soon as it flickered I got the sv003 alarm on the x and y axis and a light on that board labled HC. Any help would be appreciated
    Feb 2009
    6028
    Re: Mori Seiki MV-JR with fanuc 10M and sv003 on x and y axis
    Your going to smoke that machine with 249 volts! Waay to high. 242 is absolute maximum.
    Sent from my G-Tab Quantum using Tapatalk
    Jun 2013
    14
    Thanks, we have another phase converter to run on so we will switch it off this one. We really didn't realize that it was that hot its a factor built converter. Is there anyway to fix the output of that converter for future use. And would this be part of our problem with the OT108 and sv003 alarms
  1. help MORI SEIKI MV- 40 FANUC MF-M4
    By vladimir1409 in forum Fanuc
    Last Post: 11-19-2023, 07:56 AM
  2. Mori Seiki AL-2 Fanuc 10T
    By davesnd in forum Mori Seiki lathes
    Last Post: 11-26-2018, 07:39 PM
  3. Replies: 6
    Last Post: 06-17-2013, 04:51 AM
  4. mori seiki sl-3a with fanuc 6t
    By cmo in forum Fanuc
    Last Post: 04-05-2012, 12:24 AM
  5. Mori Seiki SL-20 Fanuc 10T
    By premier_industr in forum Fanuc
    Last Post: 12-15-2009, 02:55 PM
