586,080 active members*
3,485 visitors online*
Results 1 to 7 of 7
    Sep 2004
    38
    G-code files are required
    Help me please.
    For my researches, examples of CNC-programs (G-code) for different CNC-Controls are necessary for me. Milling, turning, turn-milling ...
    E-mail me [email protected]
    Thanks.
    Mar 2004
    1543
    Here's a prgram that makes a gasket. Would run on almost all CNC mills.
    N1 T1 M06
    N2 G00 X-.8868 Y.8695 Z.1 R.1 S3200 M3
    N3 G01 Z0 F100.
    N4 G01 X-.7487 Y-1.4545
    N5 G03 X.6812 Y-1.7238 I0 J-1.41
    N6 G01 X1.2171 Y-.5607
    N7 G03 X-.7834 Y1.0871 I0 J0
    N8 G03 X-.8868 Y.8695 I-.6373 J.8843
    N9 G0 Z.1
    N10 G00 X-1.9392 Y-.7664 R.1
    N11 G01 Z0 F100
    N12 G01 X-2.0347 Y-1.308
    N13 G03 X-1.8319 Y-1.5976 I-1.7885 J-1.3514
    N14 G01 X-1.2935 Y-1.6926
    N15 G03 X-1.0005 Y-1.4315 I-1.2501 J-1.4464
    N16 G01 X-1.1081 Y.3794
    N17 G03 X-1.3725 Y.6141 I-1.3577 J.3646
    N18 G02 X-1.7619 Y.6968 I-1.417 J1.3628
    N19 G03 X-2.0536 Y.6515 I-1.8768 J.4748
    N20 G01 X-2.464 Y.2412
    N21 G03 X-2.5334 Y.021 I-2.2872 J.0644
    N22 G01 X-2.4858 Y-.2491
    N23 G03 X-2.283 Y-.4519 I-2.2396 J-.2057
    N24 G01 X-2.142 Y-.4768
    N25 G02 X-1.9392 Y-.7664 I-2.1854 J-.723
    N26 G0 Z.1
    N27 G00 X-2.7328 Y.3259 R.1
    N28 G01 Z0 F100
    N29 G01 X-2.0444 Y1.0144
    N30 G02 X-1.7743 Y1.0129 I-1.91 J.88
    N31 G03 X-1.0567 Y1.0162 I-1.417 J1.3628
    N32 G02 X-.4623 Y1.3912 I0 J0
    N33 G03 X-.3667 Y1.4593 I-.5253 J1.581
    N34 G01 X-.1507 Y1.7407
    N35 G02 X.1507 Y1.7407 I0 J1.625
    N36 G01 X.3667 Y1.4593
    N37 G03 X.4623 Y1.3912 I.5253 J1.581
    N38 G02 X.9737 Y1.096 I0 J0
    N39 G03 X1.0804 Y1.0472 I1.1065 J1.2455
    N40 G01 X1.4321 Y1.0009
    N41 G02 X1.5828 Y.7398 I1.4073 J.8125
    N42 G01 X1.4471 Y.4121
    N43 G03 X1.436 Y.2953 I1.6319 J.3355
    N44 G02 X1.3409 Y-.5926 I0 J0
    N45 G01 X.8195 Y-1.7722
    N46 G02 X.3535 Y-2.2333 I0 J-1.41
    N47 G03 X.2738 Y-2.2953 I.4324 J-2.4171
    N48 G01 X.1507 Y-2.4557
    N49 G02 X-.1507 Y-2.4557 I0 J-2.34
    N50 G01 X-.2738 Y-2.2953
    N51 G03 X-.3535 Y-2.2333 I-.4324 J-2.4171
    N52 G02 X-.4994 Y-2.1539 I0 J-1.41
    N53 G03 X-.6108 Y-2.12 I-.6108 J-2.32
    N54 G01 X-2.2 Y-2.12
    N55 G02 X-2.4462 Y-1.9134 I-2.2 J-1.87
    N56 G01 X-2.8022 Y.1057
    N57 G02 X-2.7328 Y.3259 I-2.556 J.1491
    N58 G0 Z.1
    N59 M05
    N60 M02
    Apr 2005
    3634
    Sep 2004
    38
    Karl_T, Switcher - Thank you.
    Give me please examples for lathe work.
    Jul 2006
    25
    Quote Originally Posted by uav
    This is a roughing canned-cycle. Some machines you will need to tweak the G71, different controls handle the code in different ways, the below is for a MORI SEIKI SL-25 with a O-T fanuc control.
    Lines N007 - N016 are the profile of the part.
    Just added some notes for you.
    (FACE & TURN)
    N001 G0 G20 G40 G97 G99
    N002 G50 S2700
    N003 G97 S2200 M03 T0202
    N004 X2.562 Z.5
    G71 U.093 (DEPTH OF ROUGHING CUTs)
    G71 P666 Q668 U.02 W.01 F.010
    (P666 STARTING LINE FOR CYCLE)
    (P668 ENDING LINE FOR CYCLE)
    (U.02 HOW MUCH TO LEAVE ON DIA FOR FINISH PASS)
    (W.01 HOW MUCH TO LEAVE ON LENTH FOR FINISH PASS)
    (F.010 IS THE ROUGHING FEED, CONSTENT)
    (ALL FEEDS INBTWEEN N666 AND N668 ARE FINISHING FEEDS PICKED UP WITH THE G70)
    N666 G0 X1.
    N007 G1 Z.0 F.0035
    N008 X1.3589 F.006
    N010 X1.4955 Z-.0683 F.0035
    N011 Z-.281 F.006
    N012 X1.5124
    N013 X1.63 Z-.343 F.0035
    N014 X1.6958 F.006
    N015 X1.9699 Z-.3803
    N016 X2. Z-.3953
    N668 G00 X2.562
    N020 G70 P666 Q668 (FINISHING PASS)
    N020 Z8.
    N021 T0200 M01
    _
    ~ What was once an Opinion, became a Fact, to be later proven Wrong ~
    Jan 2006
    4396
    Multi Tasking Swiss Screw Machine
    Tsugami 6 Axis Swiss make a seat ball socket GE Fanuc 1Le Control.
    O4130
    (SEAT BALL SOCKET REV.5)
    M8
    S1000 M3
    G0 G40 G99 Y1.5 T0 M11
    G110 T0
    G100 C6.6
    G300 Z1.5
    M10
    G50 Z-.01
    G0 X1.5 Z-.03 T0 M18
    M1
    N1(FACE)
    T505 S6500 M13
    G0 X.4 Z0
    G1 X-.008 F.001
    G0 X.4 Z-.01
    X1.5 T0
    N2(SPOT DRILL 3/8 DIA.HSS)
    T1111 S1500 M13
    G0 Z-.02
    Y0
    G1 W.15 F.0008
    G4 U1.0
    G0 Z-.05
    Y1.5 T0
    N3(DRILL 1/8 DIA. 135SPT COB STUB)
    T1212 S1500 M13
    G0 Z-.02
    Y0
    G1 Z.336 F.0015
    G4 U.05
    G0 Z-.05
    Y1.5 T0
    N4(BORE .11 DIA. TRUE MADE COATED)
    (.004 TNR HONED FOR FINISH SF)
    T1313 S2000 M13
    G0 Y.6 Z-.05
    G1 Y.339 Z-.015 F.005
    Y.127 Z.091 F.00025
    Z.285 F.0005
    Y.125
    G0 Z-.05
    Y1.5 T0
    N5(FACE/TURN)
    T051505 S6500 M13
    G0 X.4 Z0
    G1 X.275 F.0008
    X.3285 F.0015
    X.3385 Z.005 F.0003
    U-.0004 Z.425 F.0005
    X.35 Z.4462 F.0003
    G0 X1.5 T0
    N6(R-GROOVE .058W THINBIT)
    T140614 S2000 M13
    G0 Y.4 Z.3142
    G1 Y.24 F.0005
    Y.349 F.01
    G0 Z.308
    G1 Y.24 F.0005
    Y.349 F.01
    G0 Z.32
    G1 Y.24 F.0005
    Y.35 F.01
    G0 Y1.5 T0
    N7(F-GROOVE .069W ROBINSON)
    T150615 S6000 M14
    G0 Y.349 Z.304
    G4 U.05
    G1Y.329 Z.314 F.0003
    Y.219
    Z.325
    Y.329
    Y.349 Z.335 F.0003
    G0 Y1.5 T0 M5
    /N8(SLOT SAW 1.25 DIA. .02 WIDE 36T)
    /(OFFSET LIVE TOOL POST .25 W/PLATE)
    /T011501 M8
    /G50 A0
    /A.9
    /M70
    /M117 (750 RPM)
    /M114 (CCW)
    /M10000 (0 DEGREES)
    /G0 X.75 Z-.05
    /X0
    /G98 G1 Z.26 F15.0
    /G4 U.05
    /G1 A-.4 F3.5
    /Z-.05 F25.0
    /M10900 (90 DEGREES)
    /G0 A.8
    /G1 Z.26 F15.0
    /G4 U.05
    /G1 A-.4 F3.5
    /Z-.05 F25.0
    /G99 X.75 M115
    G0 X1.5 T0 M71
    N12(CUT-OFF .06 WIDE)
    T061506 S3500 M13
    G0 Z.4
    X.4
    G1 X.2 F.0005
    X.349 F.003
    Z.39
    X.329 Z.4 F.0003
    X-.035 M17
    M18
    M95
    /M98 P9800
    M96
    M97
    M30
    This one puts a cam on the front of a part with a macro and again a part the machine wasn't designed to make. I didn't write this program macro, a smart friend did.
    O0001;
    (ADCO0627);
    M8
    M3S2500
    G0G99G40Y1.5T0M11
    G110T0
    G100C6.6
    G300Z1.1T051205
    M10
    G50Z-.005
    G0X1.5Z-.02T0
    N1(DRILL)
    T120412S3700M13
    Y0Z-.02
    G1Z.035F.0008
    G0Z0
    G4U.2
    G0Z.02
    G1Z.21F.0012
    G0Z0
    G4U.2
    G0Z.19
    G1Z.37F.0012
    G0Z0
    G4U.2
    G0Z.35
    G1Z.48F.0012
    G4U.1
    G0Z-.02
    Y1.5T0
    N2(CHAMFER)
    T041504S4300M13
    G0X.4Z-.02
    X0
    G1Z.072F.0015
    G4U.1
    G0Z-.02
    X1.5T0
    N4(TURN)
    T1515S5500M13
    Y.4Z-.02
    Y.08
    G1Z0F.002M52
    Y.185F.003
    Y.23Z.023F.0005
    Z.162F.002
    Y.185W.025F.0008
    G4U.01
    G1Z.235F.0015
    G4U.1
    G1Y.276F.003
    G4U.1
    G1Z.2935F.002
    G4U.1
    G1Y.352F.002
    Y.374W.011F.0005
    Z.4F.002
    G0Y1.5T0
    N5(THREAD)
    T1414S1500M13
    G0Y.4Z-.08
    Y.3
    Y.21
    G32Z.22F.0393
    G0Y.3
    Z-.08
    Y.198
    G32Z.22F.0393
    G0Y.3
    Z-.08
    Y.192
    G32Z.22F.0393
    G0Y.3
    Z-.08
    Y.188
    G32Z.22F.0393
    G0Y.3
    Z-.08
    Y.186
    G32Z.22F.0393
    G0Y.3
    Z-.08
    Y.185
    G32Z.22F.0393
    G0Y.3
    Z-.08
    Y.185
    G32Z.22F.0393
    G0Y.3
    Z-.08
    Y.245Z.0445S4500
    G4U.1
    G1Y.175W-.035F.0005
    G0Y.245
    Z.172
    G1Y.191W.027F.0005
    G0Y.3
    Z0
    G0Y1.5T0M21
    M5
    N6(MILL)
    T011313
    M8
    M70
    M10000
    G0X.6Y0Z0
    M41
    G98
    G110T1
    G100C6.0
    M41
    G101C5.9F30.0
    M41
    M20
    M41
    M104
    S4100
    M41
    G121
    G50B0
    B.18
    G98G1Z1.02B.22F50.0
    Z1.0295F5.0
    G1B[[#100/2]+.1385]F8.0
    G17G98G2U[[[#100/2]+.1083]*2]B.0295R[[#100/2]+.1083]
    G1B-.0295
    G2U-[[[#100/2]+.1083]*2]B-[[#100/2]+.1385]R[[#100/2]+.1083]
    G1B-.2
    G0W-.35
    B.22M11800
    G1W.35F50.0
    G1B-.0295
    G18G1B-.2
    G0W-.5
    Z0B0
    G120
    M41
    M105
    M41
    M21
    M41
    G110T0
    G100C6.6
    M41
    M71
    G0X1.5Y1.5T0
    N3(TAP)
    T110511S700M13
    Y0Z0
    M48
    G4U.5
    G32Z.59F.0196
    M14Z-.05F.0197
    G4U.5
    G0Z0M13
    M49
    G0Y1.5T0
    Z.25
    N7(CUT-OFF)
    T051505S3700M13
    G0X.4Z.3365
    G99G1X.385F.0015
    X.355W.015F.0005
    X.2F.001
    X-.05M17
    X.4F.015M18
    W.05
    X-.05F.0015M97
    M95
    /M98P9800
    M96
    M30
    This one has a G71 canned cycle
    O0029
    (TJD PGM HEX PRECISION GEAR)
    (321 STAINLESS)
    S1000 M13
    G110 T0
    G100 C6.6
    G300 Z1.5
    M10
    G50 Z-.02
    G0 X1.5 Z-.05 T0 M18
    M1
    N1(DRILL L .29 135 SPT COBALT)
    T1111 S700 M13
    Y0 Z-.05
    G1 Z-.02 F.002
    G83 Y0 Z.45 Q2250 R.02 F.0015
    G0 Z-.05
    Y1.5 T0
    N2(BORE .25 TM CARB COATED)
    T1212 S1000 M13
    G0 Y1.0 Z-.05
    Y.4094
    Z-.01
    G1 Y.315 W.0273 F.0005
    Z.3 F.0008
    Y.3
    G0 Z-.05
    Y1.5 T0 M5
    N3(HEX HSS SPEC GRND)
    T1313 M8
    G98 M70
    M10000(=0/DEG.)
    G0 Y1.0 Z-.1
    Y.3
    M98 P19 L20
    G0 Y.3
    M10600(=60/DEG.)
    M98 P19 L20
    G0 Y.3
    M11200(=120/DEG.)
    M98 P19 L20
    G0 Y.3
    M11800(=180/DEG.)
    M98 P19 L20
    G0 Y.3
    M12400(=240/DEG.)
    M98 P19 L20
    G0 Y.3
    M13000(=300/DEG.)
    M98 P19 L20
    G0 Y.3
    G0 G99 Y1.5 T0 M71
    N4(ROUGH-TURN)
    T505 S1500 M13
    G0 X.725 Z-.01
    G71 U.07 R.01
    G71 P101 Q102 U.005 W.002 F.001
    N101 G0 X.416
    G1 X.416 F.0008
    X.496 Z.03
    Z.1607 F.002
    X.655 Z.188 F.0008
    Z.315 F.002
    X.6875 Z.2484
    N102 G1 X.725 F.005
    G0 X1.5 T0
    N5(FACE/FINISH-TURN)
    T505 S3500 M13
    G0 X.725 Z0
    G1 X.275 F.001
    G0 X.725 Z-.01
    G70 P101 Q102
    G0 X1.5 T0
    N6(RE-BORE)
    T1212 S1500 M13
    G0 Y1.0 Z-.05
    Y.4094
    Z-.01
    G1 Y.315 W.0273 F.0008
    Z.25
    Y.3
    G0 Z-.05
    X1.5 T0
    N7(U-CUT M100 .020R 30 DEG.FORM)
    T021502 S800 M14
    G0 X.7125
    Z.2
    X.439 W-.0471 F.0008
    G0 X.5
    X1.5 T0
    N8(THD .5 20 UNJF-3A KENNAMEAL)
    /T404 S1000 M13
    /G0 Y.75 Z-.08
    /Y.62
    /G92 Y.496 W.22 F.05
    /Y.49
    /Y.484
    /Y.479
    /Y.474
    /Y.469
    /Y.464
    /Y.46
    /Y.456
    /Y.452
    /Y.449
    /Y.447
    /Y.445
    /Y.443
    /Y.442
    /Y.441
    /Y.44
    /Y.4395
    /Y.4395
    /Y.439
    /Y.439
    /G0 X.52 Z.0167 S2500
    /G1 U-.12 W-.06 F.0008
    G0 Y1.5 T0
    N9(DEBUR U-CUT)
    T202 S1000 M14
    G0 X.5304
    Z.1165
    G1 X.439 W.0264 F.0005
    X.7125 W.0471
    G0 X1.5 T0
    N10(RE-FACE FINISH TURN)
    T505 S3500 M13
    G0 X.5 Z0
    G1 X.275 F.001
    G0 X.725 Z-.01
    G70 P101 Q102
    G0 X1.5 T0
    N11(RE-THD)
    /T404 S1000 M13
    /G0 X.7 Z-.08
    /X.62
    /G92 X.442 W.22 F.05
    /X.441
    /X.44
    /X.4395
    /X.4395
    /X.439
    /X.439
    G0 X1.5 T0
    N12(C/O C-AXIS PICK-UP 21/32 COLLET)
    (C-AXIS OFFSET=5.785)
    T061506 S800 M13
    G0 X.7
    Z.815
    M41
    M21
    M103
    S800
    G110 T06
    G100 C.3
    M41
    G101 C0 F20.0
    M41
    M20
    M41
    G1 X-.03 F.0015
    M41
    G110 T0
    G100 C6.6
    G0 X1.5 Z-.05
    N13(FACE/CH 35 DEG. PROFILE 5/8SH)
    T1717(C-AXIS OFFSET=4.535)
    M8
    G0 G98 Y.725
    M103
    S2500
    M41
    G110 T1818
    G100 C.1
    M41
    G101 C.005 F3.0
    M41
    G101 Y0 F2.0
    M41
    G0 Y.675
    M41
    G100 C-.02
    M41
    G101 Y.635 C0 F1.25
    M41
    G1 Y0 F1.25
    M41
    G100 C.1
    M41
    G110 T0
    G100 C6.6
    G0 Y1.5 T0
    N14(BACK I.D. CHAMFER 5/16 TRUE MADE COATED)
    T1818(C-AXIS OFFSET=4.1724)
    M8
    G0 G98 Y1.0
    M104
    S1500
    M41
    G110 T1818
    G100 C.2
    M41
    M97
    M95
    /M98 P9810
    M96
    M30
    Want or need more, I have thousands for Milling Turning and Multi- Tasking Machines.
    :cheers:
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Sep 2004
    38
    Quote Originally Posted by tobyaxis
    :cheers:
    Thank's!
    There is quite enough.
