Here is the link to that build.
http://www.cnczone.com/forums/vertic...the-build.html
I generally just turn brass, which is akin to cutting butter. It does change speeds when I am turning aluminum, but not a lot.
That speed controller helps Mach keep it regulated pretty close to the speed called for as well. That helps.
Can't help with the Macro's, but there are plenty of pro's here that can.
